Sprockets
Jan 1, 2015 17:55:34 GMT 1
via mobile
Post by jorjasfather on Jan 1, 2015 17:55:34 GMT 1
Hi there can anyone tell me if rd125lc mk1 and mk2,3 all have the same stud pattern on the rear wheel
Post by coggan40 on Jan 1, 2015 20:45:11 GMT 1
Hi there can anyone tell me if rd125lc mk1 and mk2,3 all have the same stud pattern on the rear wheel Yes they will fit as I wanted a set for my MK1 but they only did 16/46 for the MK1 and I wanted 16/45 the guy on ebey said the MK2 16/45 will fit they are now on my bike, I couldn't use my locking tabs with them though.
Sprockets
Jan 1, 2015 21:10:41 GMT 1
via mobile
Post by jorjasfather on Jan 1, 2015 21:10:41 GMT 1
Why couldn't you use your locking tabs
Post by coggan40 on Jan 1, 2015 21:39:26 GMT 1
Why couldn't you use your locking tabs Because the MK1 sprockets are completely flat and the MK2 sprockets have a slight recess.
Sprockets
Jan 1, 2015 22:23:35 GMT 1
via mobile
Post by jorjasfather on Jan 1, 2015 22:23:35 GMT 1
Hi there I think the recess is on the rear of the sprocket which sits on the bushes and the front is flat
Post by coggan40 on Jan 1, 2015 22:44:37 GMT 1
Hi there I think the recess is on the rear of the sprocket which sits on the bushes and the front is flat No, thats not correct.
Sprockets
Jan 1, 2015 22:55:57 GMT 1
via mobile
Post by jorjasfather on Jan 1, 2015 22:55:57 GMT 1
I know years ago I had a rs125 which I put a dt175 barrel and rd200 alloy wheels but I had to have the rear of the sprocket machined to fit propperly on the bushes that why a ask if it was on back to front
Post by coggan40 on Jan 1, 2015 23:14:37 GMT 1
I know years ago I had a rs125 which I put a dt175 barrel and rd200 alloy wheels but I had to have the rear of the sprocket machined to fit propperly on the bushes that why a ask if it was on back to front They will fit mate, it will all become apparent when you go to fit them which way round they go, my locking tabs are not genuine so thats probably why they don't fit perfectly although they will go on but look unsightly, I have just bought sprockets as the gearing was wrong, and will only be doing a roadtest with the bike and will buy genuine locking tabs later.
