gsexr
Post by gsexr on Oct 9, 2015 22:33:27 GMT 1
luv these rebuild threads. Great to see it coming together
Post by midlifecrisisrd on Oct 13, 2015 18:42:02 GMT 1
Seat came back today from Tony archer with the NOS cover fitted Lovely Steve
Post by Deleted on Oct 15, 2015 18:20:25 GMT 1
Seat came back today from Tony archer with the NS cover fitted Lovely Steve As Bernard Matthews would say...... "Bootifull"
Post by JonW on Oct 16, 2015 2:30:11 GMT 1
Superb!
Post by midlifecrisisrd on Oct 29, 2015 10:12:52 GMT 1
Engine finally finished Steve Edit- just pressure tested it and all OK.
Post by unrealedd on Oct 29, 2015 22:53:56 GMT 1
That ypv engine looks a thing of beauty and nice to see your keeping the autolube functioning, One of my pet peeves is removed autolubes makes rideing a bike a ball ache imo.
Post by midlifecrisisrd on Nov 12, 2015 16:36:32 GMT 1
Picked up these beauties today Original finish and still with the machine marks on the spoke edges. Went really retro and have got a pair of new Metzeler ME33/ME99 tyres for them. Same as the ones fitted but never used. Steve
Post by midlifecrisisrd on Nov 19, 2015 0:26:44 GMT 1
Spent the evening in the shed. Engine in, tie bars fitted but then backward step taking the wheels back off in preparation for the original finish ones. I'l drop the wheels off tomorrow to get the tyres fitted Got my ultrasonic cleaner out to clean up the loom. Had to change the fluid 3 times. Do you think it was a bit dirty Even after just 3 minutes you can see the difference Need to change the Genny plug as a bit melted, luckily got a spare and a non standard connector for the temp sender. Only other repair is where the headlight wiring was spliced to fit the twin headlights so some solder and heat shrink needed. Steve
Post by budgie on Nov 19, 2015 7:09:57 GMT 1
Great work Steve, never thought of using my ultrasonic cleaner to clean up the loom.... Have heard of people throwing them in the dishwasher, but never been brave enough to do it... In case it knackered something...will give that one a go... Can't believe how much shite you got off..... That will help with my N2 build....getting ever closer to starting my thread...also... Just loving the "monsters inc" workmat.... One of my face films of all times....,!!...Keep up the good work and momentum...an inspiration for me to get cracking as the nights draw in...!
Gavin
Post by philb714 on Nov 19, 2015 7:26:54 GMT 1
Top tip on the Ultrasound to clean the wiring!!.....I wonder if work will mind me dunking my loom in their tank??
Post by JonW on Nov 19, 2015 12:32:13 GMT 1
Ive used US cleaners a few times on looms, and like Steve have found them to be excellent. What fluid did you use Steve?
Post by midlifecrisisrd on Nov 19, 2015 14:40:57 GMT 1
Ive used US cleaners a few times on looms, and like Steve have found them to be excellent. What fluid did you use Steve? You'll laugh at this.... .....bathroom cleaner. Work for a cleaning chemical company so got an abundance off different stuff kicking around. Had a bottle of concentrated washroom cleaner for hard water so is acidic. Filled the cleaner with 60 degree water then added the dose to make up a 500ml bottle so basically neat off the shelf stuff. Gave it a good dunking in fresh water afterwards to rinse and neutralise Bathroom cleaner great for many things, a lot of surfactants in it. Also use it for cleaning car wheels. Steve
Post by reggieperrin on Nov 19, 2015 16:12:41 GMT 1
good tip.. which particular cleaner should we be buying..? I've steered clear of things like Cillit Bang as I've seen some shocking damage done to Ali with it..
Post by arrow on Nov 19, 2015 17:54:33 GMT 1
Excellent work Steve, a credit to you.
Post by midlifecrisisrd on Nov 19, 2015 18:22:57 GMT 1
good tip.. which particular cleaner should we be buying..? I've steered clear of things like Cillit Bang as I've seen some shocking damage done to Ali with it.. Yes cillit bang is too strong for alloy. Avoid anything that claims to remove limescale or has bleach in it. Mr Muscle or similar should be fine Rinsing or neutralising is the key. Steve
Post by JonW on Nov 19, 2015 21:26:44 GMT 1
Post by midlifecrisisrd on Nov 19, 2015 21:45:01 GMT 1
If it kills mould it will have bleach in it. Worth a go but try a weak solution first to stop the ph being too alkaline. Steve
Post by JonW on Nov 19, 2015 23:49:28 GMT 1
Ahh ok, yeah we dont want to bleach anything... I'll keep looking, I was mostly tempted cos its from a known source who I already order from of course Cheers for reviewing mate.
Post by midlifecrisisrd on Nov 20, 2015 12:45:24 GMT 1
Spent another hour on the wheels cleaning up the black. Waiting on new bearings coming before fitting but got the tyres fitted. Check out the 80's throwback tyres Steve
Post by reggieperrin on Nov 20, 2015 19:50:12 GMT 1
I remember vividly that restoring the original black on my wheels was a pig of a job... the t-cut process took forever and then had to try and get it out of all the little pits and around the letters... well done.. they look great... Love the tyres..
Post by Gunny on Dec 19, 2015 11:38:25 GMT 1
So ??
Post by midlifecrisisrd on Dec 19, 2015 12:07:25 GMT 1
So ?? The engine is in and the replacement wheels are on Spent last night cleaning the electrical components Now p1ssin about trying to get a correct ignition switch and match locks. Last little batch of bits for plating building up Steve
Post by midlifecrisisrd on Jan 14, 2016 14:27:09 GMT 1
Got some time last night so a couple of hours spent in the shed Newly plated seat catches and nuts fitted New headlight bowl fitted along with a new ignition switch converted to correct type key seat catches fitted after being matched to the ignition key Next job is to clean the carbs out and fit them while there's plenty of room Steve
Post by midlifecrisisrd on Jan 15, 2016 22:28:38 GMT 1
God its freezing outside Original carbs had suffered from the neglect so picked up another pair. Stripped them tonight to clean them but to be honest they were spotless inside but blew them through with carb cleaner. Fitted new float valves and seats as a matter of course Just need to check the jets are correct size before refitting. Need a magnifying glass as eyes aren't what they used to be. Steve
Post by midlifecrisisrd on Jan 19, 2016 10:50:04 GMT 1
Rear master cylinder refurbed with repair kit ( had to zinc and yellow passivate ) and new clevis/pin Steve
Post by JonW on Jan 20, 2016 23:48:32 GMT 1
The rear master looks amazing, its this kind of attention to detail that sorts the men from the boys for sure.
A question re the key... Is there a list of what years got what key types anywhere? I have also struggled with finding the correct topped key for my bikes, and would have loved to see a definitive guide somewhere.
Post by midlifecrisisrd on Jan 21, 2016 9:42:54 GMT 1
The rear master looks amazing, its this kind of attention to detail that sorts the men from the boys for sure. A question re the key... Is there a list of what years got what key types anywhere? I have also struggled with finding the correct topped key for my bikes, and would have loved to see a definitive guide somewhere. Don't know about definitive but in my experience the 31k was all large tab with the white writing. 1ua models had the small tab key. All modern replacement stuff has the new shaped key Steve
Post by JonW on Jan 21, 2016 12:07:18 GMT 1
I will start a thread if i rememeber (so as not to pollute here) as this would be better with pics, I think the LC was different too... hmm..
Post by midlifecrisisrd on Jan 21, 2016 21:17:41 GMT 1
Rear master fitted with replated pedal/new rubber Next is to assemble this small fortune of NOS then fit Steve
Post by budgie on Jan 21, 2016 21:28:43 GMT 1
Looking good Steve...Home straight now surely..!!
Gav
