Post by acurrell on Dec 21, 2014 16:02:06 GMT 1
I have just sat down feeling very satisfied after I torqued down the cylinder on my LC with new gasgets etc. and was leafing through the workshop manual when I read that you shouldn't put sealant on the head gasget. I have been stripng the head on my LC for over 20 years and always used sealant. Have I been wrong? Will this cause a problem? Should I strip and replace the gasget before the engine goes back in. ?
Post by steve h on Dec 21, 2014 16:13:03 GMT 1
Used sealant every time back in the day, re using pattern head gaskets. Never had any probs, and did it many times. Just a very thin smear.
Post by arrow on Dec 21, 2014 16:18:48 GMT 1
Some say use sealant, others say not. I am in the latter group. Many have success either way.
Post by dusty350 on Dec 21, 2014 16:27:22 GMT 1
Hi, If it works and doesn't leak, I wouldn't worry. You wont want to change a perfectly good gasket. I just have and it cost me £36.00 for the privelage ! And I've still got a leak !! No leak - no problem Dusty
Post by looey on Dec 21, 2014 16:36:46 GMT 1
The thinnest smear of sealant is fine. If you put anything other than thinnest smear, it will get squashed out and possibly block the coolant passages.
If there's nothing wrong with the barrels, head or the mating surfaces on either, then they will seal perfectly well time and time again with the same gasket using a sealant.
Post by acurrell on Dec 22, 2014 9:57:35 GMT 1
Paul H
Post by Paul H on Dec 23, 2014 2:34:40 GMT 1
Which sealant would you guys recommend
higgsy
Post by higgsy on Dec 24, 2014 21:50:50 GMT 1
Threebond 1215. I always put a smear on any head gasket, even the gen ones
Post by looey on Dec 24, 2014 22:03:46 GMT 1
1104 works just as well and cleans off very easily with brake cleaner
Paul H
Post by Paul H on Dec 25, 2014 2:17:24 GMT 1
I will see if I can get a tube, cheers guys
Post by Norbo on Dec 25, 2014 10:24:30 GMT 1
I always use sealant
Post by liffy16 on Dec 25, 2014 13:03:32 GMT 1
a smear of threebond aint gunna hurt anyone its just an extra bit of insurance so you dont have to take head off again!
