Post by twostroker on Jun 2, 2007 14:40:44 GMT 1
ive got a few tuning goodies on my 125lc,dt175 piston,skimmed flywheel etc and ive been advised to use a bigger carb. my question is what carb shall i use?can some body tell me what bike has a suitable carb? if no joy i will try my standard one with a ledar nozzel and 240 main jet.
Post by mellow on Jun 2, 2007 19:00:56 GMT 1
one off a any V8 should do
Post by twostroker on Jun 2, 2007 20:17:30 GMT 1
lol,rover v8 might fit seriuosly any one know of a suitable one?
Post by twostroker on Jun 2, 2007 20:43:33 GMT 1
is it a 30 or 32mm i need?
Post by Dirtbag on Jun 2, 2007 20:58:38 GMT 1
A nice flat-side Mikuni should do the trick....off a TZR/TDR
Post by twostroker on Jun 2, 2007 21:16:45 GMT 1
sounds good,do you know what size i need ?
Post by K.B on Jun 2, 2007 21:24:12 GMT 1
I used a 34mm mikuni from a yz 125 motocross bike on my tuned Rd LC
Post by Dirtbag on Jun 2, 2007 21:37:44 GMT 1
32mm or 34mm not much between em'......not so that you'd notice anyway
Post by Deleted on Jun 2, 2007 22:47:59 GMT 1
what mark 125 is it? mk1/2 had a 24 mm mk3 got a 26mm. 26mm will do if you can get hold of a full ledar kit plus an extention tube then your air filter (if you are using a s+b or k+n type) if not go the 34mm yzr type.
Post by twostroker on Jun 3, 2007 7:34:56 GMT 1
its a mk2 with a mk1 carb with ledar nozzel and 240 main jet(not full ledar kit),ive been told a suzuki x7 carb was a popular conversion back in the 80's? i dont realy want a motorcross carb cos i want to keep the autolube,i realy want to find out what carbs other people have tryed before i buy one.
Post by pablo on Jun 3, 2007 11:49:39 GMT 1
pretty sure the carb on the X7 aint got an oil feed pipe...if memory serves...might be worth trying to look at one before you buy one
Post by twostroker on Jun 3, 2007 18:35:53 GMT 1
i asked a guy selling a pair of x7 carbs about oil feeds and he said that the set he has got doent have oil feeds and possably came off a tz350 racer,so im not sure if they do or not? ive noticed aprilia rs125's have a 32mm carb,just they use a dollereto carb and im unsure if it will fit. please help somebody?
Post by Norbo on Jun 5, 2007 17:46:26 GMT 1
People have used the 32mmcarbs on theys kits but anything biger them a 28 and it will feel quight bogey ar low revs . It iot tuned but its not a full race tune and to big on the carb will not get the most out of it .
Post by twostroker on Jun 5, 2007 18:09:26 GMT 1
im struggling to find a 28mm but ive been offered a ty175 carb,the guy THINKS its a 27mm intake,does any body on here know?
Post by pablo on Jun 17, 2007 22:52:40 GMT 1
would the TY have autolube?
Post by twostroker on Jun 18, 2007 17:49:40 GMT 1
i asked a guy selling a ty 175 if it hap a oil feed nipple for auto lube and his didnt,he said he thinks they were premix only, ive changed my mine now and decided to run pre mix now as the 125 is only a toy for the weekend and i dont mind mixing the oil/fuel and atleast no oil pump is one less thing to worry about.
Post by pablo on Jun 18, 2007 18:19:32 GMT 1
my sentiments exactly ;D
Post by twostroker on Jun 18, 2007 20:40:39 GMT 1
have you still got the carb then?
Post by pablo on Jun 18, 2007 21:03:31 GMT 1
what carb?
Post by twostroker on Jun 19, 2007 20:21:10 GMT 1
sorry my mistake,when you said "my sediments exactly" i thought you was the guy on ebay selling the ty carb.
Post by pablo on Jun 19, 2007 20:42:32 GMT 1
;D nah im just running pre-mix
Post by twostroker on Aug 11, 2007 11:27:25 GMT 1
incase any bodys interested ive found a nice pair of kr1s carbs from fleabay that have had the top of the venturi machined out into an egg shape for a bit of extra power,origanally the kr1s carbs are a pair of 28mm kehinin flatslide's so fingers crossed when its back together again it should run and go well,it was even a nice straight forward swap over with only a minor tweek needed to the cable.
Post by pablo on Aug 11, 2007 19:44:36 GMT 1
;D bolt them on...then the REAL fun begins
Post by twostroker on Aug 12, 2007 12:35:09 GMT 1
the kr1s carbs look like a nice(and cheap i paid £30 ror 2) upgrade for a 250/350lc too,has any one else seen carbs that have been reprofiled internaly from a 28mm round hole to a more egg shape hole measuring around 29.5mm,i think this must be a race bike mod as the carbs were off an kr1s ex race bike? i would post up a picture but im lacking a digi camera at the mo'
Post by Norbo on Aug 17, 2007 16:32:03 GMT 1
They are a good carb. The best for a ypvs .
Post by twostroker on Nov 14, 2008 19:57:23 GMT 1
ive finaly got it surprisingly fast fot a 125lc,next mods are to fit my bigger dtr125 clutch when i recieve my gasget set and heavy duty clutch springs to cure my clutch slip,then im going to enlarge the inlet on the barrel to fit some v-force reeds and a bigger fuel tap.
im also thinking of sending my barrel back off the the guy who fitted the liner/tuned it to enlarge the inlet instead of me doing it and maybe ading 2 more inlet ports like on race tuned/motocross barrels?? decissions, decissions
Post by Norbo on Nov 17, 2008 12:32:57 GMT 1
may be the later RG 125 carb would a good mod . they are nade for a fast 125. its just a get what you and fit it and see if it works i think . Whayt ever you get the jetting is going to take a while to sorght out
Post by twostroker on Nov 17, 2008 21:41:59 GMT 1
may be the later RG 125 carb would a good mod . they are nade for a fast 125. its just a get what you and fit it and see if it works i think . Whayt ever you get the jetting is going to take a while to sorght out can you recall what carb them rg's use norbs? im currently running a pwk28 thats been machined out to just under 30mm,power comes in strong @7500 and it will stay in the band right through the gears,infact its got the power to go 1 tooth larger on the front sprocket but id rather stick to acceleration rather than top speed, ive seen a inlet mod where another 2 holes are made,usualy on race tuned/motor cross barrels,is this ideal?
