Post by twostroker on Feb 22, 2007 22:38:27 GMT 1
I'm putting my mk2 125lc back together next week,well hopefully,its in 3 boxes at the mo , any way will have~ skimmed flywheel,220 main jet,ledar nozzle,swarbrick racing spannie,carbon reeds and a reed spacer. I'm not sure if to re fit the k&n or to fit a standard air box from my spares? i know it will probably sound nicer with the k&n but I'm thinking theres more chance of a bit of bottom end power and less of a flat spot with the air box? i haven't been on one of these for years so I'm not relay sure.
Post by Dirtbag on Feb 23, 2007 8:43:35 GMT 1
If you fit the K+N..... fit the extension tube....this irons out the bottom end flatspot
Post by pablo on Feb 23, 2007 21:05:12 GMT 1
if you've got both you can do a back to back test and post up the results on here ;D
Post by twostroker on Feb 24, 2007 0:06:49 GMT 1
ive got both so i will give them both a go,i havent got the extension tube for the k&n (its probaly a cheap cone filter not a genuine k&N).i was hopeing the reed spacer would help smooth out the flat spot.
Post by Dirtbag on Feb 24, 2007 8:05:23 GMT 1
How wide is the reed spacer mate ? , alot of tuning info sites recommend at least 8mm , with the extension being 30mm
Post by pablo on Feb 24, 2007 14:48:49 GMT 1
post up some links then Dean
Post by twostroker on Feb 24, 2007 17:10:40 GMT 1
any links would be much appericated im pretty sure the reed spacer is 8mm
Post by racerd on Aug 27, 2008 0:59:18 GMT 1
or you could try removing the reed spacer and using just a spacer tube 60mm length and yep that is a 32mm carb that runs on my lc also uses a ram air filter
Post by Deleted on Sept 21, 2008 22:59:24 GMT 1
my hybrid tuner simply does not rate the reed spacer at all, it enlarges the area in front/behind (from which ever perspective you use) the reed block/piston creating even LESS upward pressure for the 2 stroke cycle therefore loosing power! the best way to eliminate a 'flat spot' using a k+n/s+b filter is the spacer: the 'general' consensus is a minimum of 60mm but longer is OK
Post by carlos on Sept 23, 2008 17:17:24 GMT 1
That makes sense Jamie, the point of the reed valve is to stop charge going back through the carb, if you move this further from the barrel it'll take longer for the pressure to equalise as it'll have more volume to compress in!
Post by racerd on Sept 23, 2008 21:15:18 GMT 1
reed block spacer are also used so you can lift you the reed stops more
Post by bertiemollie on Oct 4, 2008 19:07:15 GMT 1
First time I have ever seen anyone recommend baby food packaging to tune an LC LOL What next nappies for air filters . or you could try removing the reed spacer and using just a spacer tube 60mm length and yep that is a 32mm carb that runs on my lc also uses a ram air filter
Post by johnlc on Oct 10, 2008 2:27:43 GMT 1
Wouldn't use a k+n filter only ramair as you don't need a spacer with them as they have no metal back
Post by tzrman1984 on Jan 3, 2009 15:21:25 GMT 1
so let me get my head round this if idecided to use a ka nd n filter on the 39m carb i have for my tzrr engine then it will allow the bike to run more effiect yeah (or is the idea of the spacer tube jsut to stop it from fluffling up the bottom end
