Post by marddy on Nov 22, 2014 20:59:47 GMT 1
Hi,
I have tried my best to get my front brake system to work....but, the Caliper is not functioning. I have the following options - [1] buy a new/refurbished caliper [2] buy a seal kit [3] fit any modern day caliper.
Please let me know which modern day caliper fits and works well.
Cheers,
Post by rsvr1000 on Nov 23, 2014 10:24:18 GMT 1
Have you repaced any of the seals or Pistons ? Are Pistons free to move? Callipers are quite easy to refurb yourself.
Post by marddy on Nov 24, 2014 11:37:45 GMT 1
Have you repaced any of the seals or Pistons ? Are Pistons free to move? Callipers are quite easy to refurb yourself. The system was working fine till we disassembled to spruce up the bike ...painting, chrome zinc etc. It is not working after reassembly.
Post by rsvr1000 on Nov 24, 2014 19:22:50 GMT 1
It sounds like you might have a air leak, have you any signs of fluid ? Have you tried a syringe to draw the fluid through ? The front brake is normally the easier one to do, the back brake is a bitch !
Post by marddy on Nov 25, 2014 10:41:32 GMT 1
No Air leaks. Still does not lock.
Post by rsvr1000 on Nov 25, 2014 19:18:11 GMT 1
Have you refurbed the master cylinder ?
Post by rsvr1000 on Nov 26, 2014 12:46:59 GMT 1
Have you refurbed the master cylinder ? The small hole with the base of the master cylinder may be blocked, this may be the issue, also go to the air cooled forum and try the search for belle ding brakes some good info on there
Post by butchers on Dec 8, 2014 23:11:11 GMT 1
replied to pm sorry for the delay
