paul25
Oh dear
Oct 12, 2014 19:16:08 GMT 1
Post by paul25 on Oct 12, 2014 19:16:08 GMT 1
Another run out today, all was well. Both John and Jimmy came past me, as that happened to johns, jimmys seized at the same time, strange.
Oh dear
Oct 12, 2014 20:30:30 GMT 1
Post by broughton5 on Oct 12, 2014 20:30:30 GMT 1
now thats the kind of luck i get bad, hope they find the root of the problem.
Oh dear
Oct 12, 2014 20:40:38 GMT 1
Post by looey on Oct 12, 2014 20:40:38 GMT 1
Ooooops They very rarely have timing issues, so would suspect jetting or a serious air leak (induction, or left crank seal etc.)
Oh dear
Oct 12, 2014 20:49:14 GMT 1
Post by rob99 on Oct 12, 2014 20:49:14 GMT 1
Oh ah oooops
kath
Oh dear
Oct 13, 2014 5:07:47 GMT 1
via mobile
Post by kath on Oct 13, 2014 5:07:47 GMT 1
ooooops..not good then.
Oh dear
Oct 13, 2014 16:25:10 GMT 1
Post by jackjoe on Oct 13, 2014 16:25:10 GMT 1
Ooooops They very rarely have timing issues, so would suspect jetting or a serious air leak (induction, or left crank seal etc.) unless the wooduff key has sheared
Oh dear
Oct 13, 2014 17:38:39 GMT 1
Post by looey on Oct 13, 2014 17:38:39 GMT 1
Good point but that doesn't happen very often on them either, unless the Cowboys have in there......lol
Oh dear
Oct 13, 2014 20:24:13 GMT 1
Post by jackjoe on Oct 13, 2014 20:24:13 GMT 1
yaa hoo
Oh dear
Oct 13, 2014 21:26:36 GMT 1
Post by looey on Oct 13, 2014 21:26:36 GMT 1
LOL
Oh dear
Oct 13, 2014 21:37:27 GMT 1
via mobile
Post by rob99 on Oct 13, 2014 21:37:27 GMT 1
Yeee haaaaa
Post by Bertie Wooster on Oct 19, 2014 9:41:38 GMT 1
Not the thing you want to see when removing the head what a bugger
Oh dear
Oct 19, 2014 14:13:59 GMT 1
Post by stusco on Oct 19, 2014 14:13:59 GMT 1
The worst bit for me is taking the plug out with your fingers crossed praying its not covered in aluminium
Post by lcmadmartyn on Oct 21, 2014 1:22:40 GMT 1
and it looks like it would have been
Oh dear
Oct 27, 2014 21:24:48 GMT 1
Post by johnhonda on Oct 27, 2014 21:24:48 GMT 1
Its busy getting rebuilt as we speak.
...Yee ha!
Post by johnhonda on Nov 8, 2014 21:30:00 GMT 1
The barrel is on its last rebore .2mm. does anyone know if its possible to get a .25 piston?
The clutch and basket are knackered and it's going to need a bit of welding where a snapped chain in its past life has weakened the cases.
Oh dear
Nov 11, 2014 10:56:56 GMT 1
Post by Norbo on Nov 11, 2014 10:56:56 GMT 1
You can use a TZR125 piston mate you still have a couple more bores left
Post by Eyrey1 on Nov 12, 2014 0:52:08 GMT 1
looks like an air leak! did you find anything when you stripped it ?
Oh dear
Nov 12, 2014 20:17:45 GMT 1
Post by johnhonda on Nov 12, 2014 20:17:45 GMT 1
You can use a TZR125 piston mate you still have a couple more bores left Cheers for this, I'll look into it.
Oh dear
Nov 12, 2014 20:21:11 GMT 1
Post by johnhonda on Nov 12, 2014 20:21:11 GMT 1
looks like an air leak! did you find anything when you stripped it ? I didn't, the only thing that I can think of was that I foolishly didn't re-jet after fitting my new Gibson exhaust. It did have a micron on it so I kind of thought it would be OK. I should know better.
Oh dear
Nov 12, 2014 20:36:38 GMT 1
Post by looey on Nov 12, 2014 20:36:38 GMT 1
If it was jetted ok for a Micron fitted it deffo won't need a bigger main jet for an Allspeed with no other changes.
Must be something else for that to happen.
What carb and main jet are you running ?.
Oh dear
Nov 12, 2014 20:45:06 GMT 1
Post by johnhonda on Nov 12, 2014 20:45:06 GMT 1
Hi Looey, it is running the standard carb and to be honest I haven't checked to see what jet is in it, the bike and parts (carb) are in my shed which doesn't have a light in.
Cheers for the reply, I will dig it out over the weekend and check and report back.
Oh dear
Nov 12, 2014 21:41:56 GMT 1
Post by looey on Nov 12, 2014 21:41:56 GMT 1
Ok mate, Best find out what carb it is (12A, 10W 1GU etc.) and also what main jet is fitted before you go riding it again . Let us know
Oh dear
Nov 12, 2014 23:48:45 GMT 1
Post by Eyrey1 on Nov 12, 2014 23:48:45 GMT 1
what looey said above id do a leak down test on it before i ran it mate my mates bike had a mend on the crankcase and just a slight crack that they missed didnt even look like it would be a problem but rd400 went bang !
Oh dear
Jan 12, 2015 19:17:32 GMT 1
Post by johnhonda on Jan 12, 2015 19:17:32 GMT 1
Hello everyone I should have my engine back this week, it has had the crankcase welded where previous chain damage had not been fixed, it has also had the clutch basket/gear replaced, a new barrel, cylinder head and loads of things sorted that were not right. I am dropping the tank off to get painted after it was knocked in the shed which made petrol run out of the cap and ruin the paint, I will be checking the jetting and also the needle position before it goes on the road. It has been tuned a bit too. (don't want to say to much as Paul25 will be looking)
Oh dear
Jan 12, 2015 19:26:51 GMT 1
Post by johnhonda on Jan 12, 2015 19:26:51 GMT 1
Oh dear
Jan 12, 2015 19:28:10 GMT 1
Post by johnhonda on Jan 12, 2015 19:28:10 GMT 1
Oh dear
Jan 12, 2015 19:29:13 GMT 1
Post by johnhonda on Jan 12, 2015 19:29:13 GMT 1
I have also managed to get a stand from a mate who has the other Red 125 in my profile picture. Cheers Jimmy.
Oh dear
Jan 12, 2015 20:31:54 GMT 1
Post by broughton5 on Jan 12, 2015 20:31:54 GMT 1
with a pin aswell lucky so and so,been after a pin for ages one went on ebay last week for £27 i dont think so somehow.
Post by johnhonda on Jan 17, 2015 18:40:04 GMT 1
Oh dear
Jan 17, 2015 18:43:23 GMT 1
Post by johnhonda on Jan 17, 2015 18:43:23 GMT 1
Me on the left with my mates 125lc that I crashed in January 1983, I sprayed the frame and wheels Red and fitted a 350lc headlight.
The motor was tuned by ARD on westagte road Newcastle, it went canny good after that and I didn't crash it again.
The other photo is of me at Brands in 1983 also
