Post by jackjoe on Oct 2, 2014 14:37:53 GMT 1
I have rebuilt fizzdog bike and it runs fine temp gauge reads ok but there is steam coming from the plastic return tank after about 6 miles I have replaced the rad and cap any suggestion's please
Post by looey on Oct 2, 2014 15:39:49 GMT 1
If it ain't the Radiator or Cap, then it's looking very much like a head gasket leak . Could be a warped head or crap surfaces if it's already had a new Head Gasket ?
Post by jackjoe on Oct 2, 2014 17:06:18 GMT 1
If it ain't the Radiator or Cap, then it's looking very much like a head gasket leak . Could be a warped head or crap surfaces if it's already had a new Head Gasket ? that's what im thinking but it doesn't seem to be overheating unless my sender is reading wrong
Post by looey on Oct 2, 2014 17:18:00 GMT 1
Chuck a sender in it out of another 125LC that's running ok, if it's still the same, then run a wire from the sender of the bike that's got the problem to the clocks of another 125LC that you know the temp guage is working ok ?.
Will at least eliminate the sender the the temp guage reading wrong ?.
Post by jackjoe on Oct 2, 2014 19:08:24 GMT 1
Post by Eyrey1 on Oct 3, 2014 0:08:57 GMT 1
what looey says !
Post by jackjoe on Oct 7, 2014 13:32:17 GMT 1
looey you is the man it was the head
