Post by K.B on May 24, 2006 21:12:41 GMT 1
HI I have restored a RD250 LC and have a problem with it . The engine starts first kick and revs cleanly when not under load But when I ride it the power is good until about 5000 revs then it splutters and the power is flat and it does not pick up revs. I have cleaned the carbs and all the jets, checked the reed valves and the stopper heights, new plugs and air filter, balanced the carbs. I am going to decoke the exhausts and recheck the oil pump settings to see if this helps. Does anyone have any advice ? It does not pull past 50 mph HELP !!!!!!!!!
Post by pablo on May 24, 2006 21:24:35 GMT 1
hmmm...what did you do to the motor mate...did it run okay before you restored the bike?...any engine work at all?...or was it running ok then went pants on you?...did you check the timing at all?...and is it running on both cylinders?...
Post by K.B on May 24, 2006 21:31:55 GMT 1
The motor is standard I just honed the bores and changed all the oil seals , new clutch and springs , it is running on both cylinders. IT has good compression
Post by pablo on May 24, 2006 21:41:06 GMT 1
did the slides go back in the right carbs?...can you see the little dots in the windows?...
Post by K.B on May 24, 2006 21:46:29 GMT 1
The slides are in the correct carbs, the holes line up with the the windows
Post by pablo on May 24, 2006 21:50:43 GMT 1
and it was running ok before the hone?...
Post by davesyam on May 24, 2006 21:52:10 GMT 1
hi mate, i had the same prob on my 250 a few moons ago it turned out to be the float valves sticking, just make sure the bowls are clean and give the jets a blast with an airgun, sorted mine out ! hope it goes for you mate.
Post by K.B on May 24, 2006 21:54:28 GMT 1
I don,t know wot the motor was running like b4 the hone because I brought the bike dismantled and the top end was off.
Post by pablo on May 24, 2006 21:58:32 GMT 1
think davesyam could be right about the floats sticking mate...would make it run out of fuel...not really a problem at standstill...only notice it on the move...either that or the float height like borrie says...does sound like its not getting enough fuel on the move...could try giving the bowls a little tap before you strip the carbs again...
Post by K.B on May 24, 2006 22:01:24 GMT 1
Thanks pablo I will try that !
Post by pablo on May 24, 2006 22:02:38 GMT 1
;D he,he...i think about 12 other people said it mate... ...hope thats it... do it now...wake the neighbours up... ;D ;D ;D
Post by K.B on May 24, 2006 22:17:02 GMT 1
I already set next doors house alarm off when I start up my k2 GSXR it,s got a race akrapovic system
Post by mellow on May 24, 2006 22:26:15 GMT 1
lovely pipes them akros ;D
Post by pablo on May 24, 2006 22:49:29 GMT 1
hmmm...this sounds suspiciously like that other fellows problem his bike revs to 7 grand then stops... it was you rizkat!!! got it sorted then fellah...had to just check the other post...
Post by pablo on May 25, 2006 0:39:16 GMT 1
what have you done to it so far to get where you are now riz...?
Post by Norbo on May 25, 2006 18:10:31 GMT 1
It could be the stator plate behined the fly wheel braking down and not working on the higher revs coils. could be crank seals put in wrong what do the plugs look like after a ride same couler on both of them ? you will need to put old plugs in to check this . Could be something simple like the wrong flote bole on the wrong carb. If you look in side both have then 1 has a small holl in it you will see what i meen when you look this bole should go on the choke carb. Hope this helps .
Post by K.B on May 25, 2006 21:44:46 GMT 1
Thanks Norbo I will check the float bowls. I think it could be the coil or plug caps. I have checked everything else except the stator.
Post by stevebozzy on May 31, 2006 15:34:40 GMT 1
:-[hi everybody,i am new to this site today,i have bought a 250lc last week. it was running then but not now ! i was advised by norbo to read this site for info.it ran ok untill 7000rpm then went onto 1 cylinder ,soon as i slowed down it was ok again. now it will only start with a push ! anybody know what psi should the compression be. reading your forum ,it seems quite a common problem.i will try all the advice listed,should keep me busy for a while. the bike is a 1982 german version that has been stood for a while. thanks steve lancs
Post by stevebozzy on May 31, 2006 15:36:32 GMT 1
Post by pablo on Jun 1, 2006 18:55:00 GMT 1
know all...
Post by stevebozzy on Jun 1, 2006 20:17:26 GMT 1
thanks for advice and moral support,will keep you posted. steve
Post by mellow on Jun 2, 2006 21:32:24 GMT 1
u bought a cat baggy
Post by mellow on Jun 3, 2006 16:19:23 GMT 1
Post by Norbo on Jun 5, 2006 10:21:50 GMT 1
thanks for advice and moral support,will keep you posted. steve Good old tweetypye told you people on here are friendly and helpfull. Mined you take you week to go through his list LOL ;D
Post by stevebozzy on Jun 16, 2006 15:00:38 GMT 1
hello everybody, i have found why my bike wont rev past 7000rpm, one of the main jets had fell out and was rolling about in the bottom of the float bowl. this is my own fault,i must not have tightened it up ,after i blew them out.OOPS please feel free to mock. steve yours
Post by alibongo on Jun 16, 2006 16:32:57 GMT 1
Doh! Easy mistake innit? Have some Karma to cheer you up. ;D
Post by mellow on Jun 16, 2006 16:44:28 GMT 1
this is my own fault,i must not have tightened it up ,after i blew them out.OOPS please feel free to mock. steve yours ok then..............u doughnut DOH!!! ;D
Post by pablo on Jun 16, 2006 22:06:44 GMT 1
hello everybody, i have found why my bike wont rev past 7000rpm, one of the main jets had fell out and was rolling about in the bottom of the float bowl. this is my own fault,i must not have tightened it up ,after i blew them out.OOPS please feel free to mock. steve yours ;D
Post by Norbo on Jun 19, 2006 9:02:03 GMT 1
hello everybody, i have found why my bike wont rev past 7000rpm, one of the main jets had fell out and was rolling about in the bottom of the float bowl. this is my own fault,i must not have tightened it up ,after i blew them out.OOPS please feel free to mock. steve yours If you insist Mock, Mock, Mock, Mock, Mock, And a karma from me to cheer you up after sutch a mocking ;D
Post by stevebozzy on Jun 19, 2006 12:11:23 GMT 1
thanks for karma,s .what does it mean ? ,what do the stars next to your name mean ? how do i put location and gender next to my name. my temp gauge is not working now,its not the sender,must be the rev counter.does everybody spend more time in the garage ,than riding thier bikes ,or is it just me ? i think i am becoming addicted ! steve
