Post by jorjasfather on Sept 15, 2014 12:29:54 GMT 1
Hi there everybody can any help me im wanting to know if the the caliper splits in two so you can changed the pistons and if there is a seal or gaskets in the middle of both parts thanks guys
Post by museumman on Sept 17, 2014 21:47:20 GMT 1
yes it splits with the 2 14mm bolts, theres 2 rubber washers between the transfers
Post by jorjasfather on Sept 19, 2014 7:43:46 GMT 1
Thanks a lot wasnt to sure what in between both half unless i split now i can sort many thanks for that top guy
