Post by johna on Aug 30, 2014 19:48:21 GMT 1
hello gents is there anyone in the south yorkshire area with a rd400e that i could use to compare to mine i'm having real problems getting some expansion chambers i had made to fit properly they catch both the brake and gear lever. many thanks in advance john
Post by stfocus on Aug 30, 2014 20:55:59 GMT 1
Hi pal whos pipe r thay would help pal to stat with
Post by johna on Aug 30, 2014 23:14:21 GMT 1
allspeed copies but made to keep the centre stand like the c and d models.
Post by muttsnuts on Aug 31, 2014 10:42:49 GMT 1
I am in North Yorkshire if that helps, but it sounds like they are not right for the bike if they are catching
Post by oldelsieboy on Aug 31, 2014 10:42:55 GMT 1
allspeed copies but made to keep the centre stand like the c and d models. Assume they are Gibson pipes then. Best to contact them to discuss the problem. OEB
Post by tsa on Aug 31, 2014 16:42:35 GMT 1
I had this issue with an RD400E on my last build. It had to ditch the centrestand and fit a different sidestand to get anything resembling a good pipe design in there. But here is a pic if you want to see them.
Post by johna on Aug 31, 2014 18:55:33 GMT 1
thanks for the replies gents. john
Post by rdjames on Sept 2, 2014 12:23:24 GMT 1
thanks for the replies gents. john John try the left on the right side and the right on the left.... just try
