Post by marddy on Aug 23, 2014 7:40:54 GMT 1
Hi,
I have a Hydraulic Clutch from a Honda VT250. Please advice how to fit it in my C model RD.
Post by spondon440 on Sept 2, 2014 22:54:14 GMT 1
There is a technical post on converting to a hydraulic clutch on the aircooled rd forum.
Andy
Post by botty on Sept 2, 2014 23:41:01 GMT 1
Post by marddy on Sept 4, 2014 12:16:47 GMT 1
Thanks mate...I have a good reference point to start with now.
Post by gibba1008 on Oct 14, 2014 9:25:30 GMT 1
have you made any progress? I used a bandit slave cylinder with a magura master cylinder....
Post by gibba1008 on Oct 14, 2014 9:26:11 GMT 1
that was for a 350b tho....
Post by marddy on Oct 14, 2014 19:46:07 GMT 1
have you made any progress? I used a bandit slave cylinder with a magura master cylinder.... No Gibba. Low on confidence to do the mod...pretty unsure if it will be a success.
Post by dusty350 on Oct 14, 2014 20:40:06 GMT 1
Hi, I did it on a 400e - Yzf master cylinder, braided line, Triumph slave cylinder, a 3mm ally plate to mount the slave to the casing, and a 400 pushrod with a threaded boss welded on the end to allow a threaded bolt to be used so you could adjust the length of the rod to get optimum clutch actuation; I used a cylinder head bolt with the end cut off, then welded onto the pushrod, hence the picture. It makes gtting the clutch action easy coz with a threaded bolt screwed into the end, anda locknut, you can adjust the length rather than guess it. Dusty
