Post by antzz1964 on Jun 25, 2014 20:22:03 GMT 1
Hi, i have owned my 350ypvs for 3 years now and don't get to use it much, hence why i have never had to buy any 2 stroke oil, now the red lights on, the question is which oil to buy, when i owned a 350lc in the 80s there was only one type of 2 stroke oil, now there are all sorts, synthetic, semi synthetic, scooter 2 stroke oil, ect. Which one do i get??? with modern oils do you have to back the auto lube off
higgsy
Post by higgsy on Jun 25, 2014 20:55:01 GMT 1
No don't back the autolube off! I always think you should use the best oil you can, but most oils these days are far better than what we used to use back in the day
Personally for a road bike I would use Motul 710 or Castrol Power 1
Post by rich on Jun 25, 2014 21:10:16 GMT 1
Post by antzz1964 on Jun 25, 2014 22:46:02 GMT 1
Thanks for your help guys.
Post by looey on Jun 25, 2014 23:18:21 GMT 1
I'm using the Exol Optima Racing Oil as well in various bikes. No problems so far
Mad Biker
We lead others try and follow.
Post by Mad Biker on Jun 25, 2014 23:21:31 GMT 1
I never had any probs using Castrol Power one and now im using Castrol XR77 and its all been good
Post by Deleted on Jun 26, 2014 20:44:16 GMT 1
Post by midlifecrisisrd on Jun 26, 2014 21:01:54 GMT 1
I have run my tuned motor since the motor was built on Putoline TT sport which is fully synth and £10 a litre from local bike shop.
Done 600 miles now ( only run in for 100 ) and putting out mid 70's at wheel. Had pipes off 100 miles ago and had a look up the port and pistons and bores perfect
Post by antzz1964 on Jun 28, 2014 11:27:36 GMT 1
Thanks for all your reply's, decision time. :-)
Post by copper99 on Jun 28, 2014 16:52:49 GMT 1
I dont think you can too far wrong on any branded semi synth mate..dont fret over it too much, the lack of use is more likely damaging the engine more than what brand of oil your considering..
Post by bazzer5115 on Jun 28, 2014 17:03:08 GMT 1
Running my fast road tuned ypvs on motul 800,70bhp at back wheel.Running pre mix at 30-1. Done 1,500 hard miles and took exhausts off and looked up ports,pistons,bores,head,power valves all look like the engine just been assembled,but at £19/litre it's bloody expensive.Smells pretty good also. With super unleaded at £6/gallon and oil at nearly £4 pre-mix/gallon and hard riding consumption at 20mpg.£10 to go 20 miles!!
Post by dave1963 on Jun 28, 2014 17:14:50 GMT 1
HI i use same exol oil done over 1000 miles seams ok on my 2nd bottle
