Post by okeydokey on Jun 6, 2014 20:30:01 GMT 1
Got a 125LC engine in bits, and am starting to prep for a rebuild. I have not heard this engine running and its been sat in pieces for a while. Now although the big end feels fine am not sure about the end float on it. Anyone know the clearance between the thrust washer and web? or is it measured the other side? thrust to conrod? Whats the going rate for a crank rebuild these days? (just in case )
Post by yamark on Jun 7, 2014 10:25:41 GMT 1
Yamaha give 2 measurements ,big end side clearance 0.2-0.7mm. big end deflection-at small end 2mm. Sorry don't know rebuild cost Norbo's showing £30 for conrod kit , £40/£50 to press an true is my guess. HTH
Post by okeydokey on Jun 7, 2014 17:05:11 GMT 1
Well it's coming in at 0.5mm side clearance, will try measure deflection somehow when i work out how with what i have to hand! Lol
