Post by 2strokesniffer on May 21, 2014 6:43:42 GMT 1
Hi to all out there, my daughter is 17 in 2 weeks and purchased herself a clean and tidy ish 1985 lc, my problem is it will only ocasionally start from kick, it bumps piece of piss within 6 foot, and runs lovely, there plenty compresion, good spark and fuel there, just need one of you good fella's to guide me to what it might be?
Post by rob99 on May 21, 2014 18:46:57 GMT 1
Mag windings might need replacing or refurbing with there not been enough from the kickstart and when you push it off the mag will be spinning alot more
Just a possability not gospel lol
Good luck
Post by eddie1969 on May 21, 2014 18:53:39 GMT 1
Hi, Could be mag windings But first to check all wiring connections,especially earthing May help to make extra earthing. Wire from frame to engine Good luck with it
Post by 2strokesniffer on May 21, 2014 19:40:28 GMT 1
Thanks gents for getting back to me, couple things to check and ill post to what happens
Post by stinkwheel on May 22, 2014 7:32:06 GMT 1
Does it run good when push started, i remember that unwilling to start on the kick symptoms can be slightly leaking crank seals.
Post by museumman on May 25, 2014 12:10:16 GMT 1
Check the mixture (colour of plug) after a run and if its running weak, stinkwheel will be right, probably left crank seal.
