Post by rob99 on May 3, 2014 7:48:37 GMT 1
Whats your thoughts on conrods
In the past if the big end was going i would just replace the full conrod but i suppose if there is no damage or ill treatment to the rod why couldn't i just change the bearing..... Or is this not advised
Your thoughts
Post by mudguts on May 3, 2014 15:05:16 GMT 1
conrods and the eyes can stretch, i got a yambits one in mine now, jap kit made by long, fitted by yamaha as standard. been in for 2 years of thrashing still fine. if bearing went i would fit a new rod too as it would be false economy not to replace it, unless i was well skint of course.
Post by rob99 on May 3, 2014 16:01:37 GMT 1
Well the bearing hasn't gone as such it was really just while it was out I could just replace the bearing I'm sure the rod is ok think I might risk it and just replace the bearing
Post by billy on May 10, 2014 22:54:42 GMT 1
The only reason to only replace the conrod bearing is if you're paranoid that the old bearing cage has worn thinner and might take a cr*p on you. If you have play in the conrod, then replace it all. The conrod wears far more than the bearing rollers.
