Post by mikeley on Apr 30, 2014 20:27:30 GMT 1
On the right hand side crankshaft seal there is a spacer between the seal and the shaft. What stops the gearbox oil being drawn in through the gap between the spacer and the shaft as this is obviously not an air tight seal as the spacer just slides over the shaft?
Post by rob99 on Apr 30, 2014 21:32:30 GMT 1
Your right in what you say its a weired set up but it works
Post by mudguts on May 1, 2014 20:53:15 GMT 1
never thought of that, perhaps its a pressure thing
Post by jollyr6 on May 1, 2014 23:08:34 GMT 1
If I right in what your thinking about it's called a labor into seal n yes it stops oil vortex ing through seal last one I fitted was 3foot in diameter n it stopped oil leaking out gbox hth
Post by mudguts on May 2, 2014 5:36:25 GMT 1
not lost or gained any oil yet, so yam must have it right, did use a new spacer at rebuild time, about £9 i think
