Post by gazbeemer on Apr 18, 2014 17:52:19 GMT 1
Bike is a mk1 rd 125 lc with mk2 engine fitted. Sprocket oil seal is leaking slightly. Am I correct in thinking I can remove sprocket and pull seal from outside then drift a new one into position. Any tips or hints ? Cheers guys
Post by rob99 on Apr 18, 2014 18:38:54 GMT 1
Its worth a shot deffanatly just make sure you dont turn the seal inside out on the sprocket shaft end
Good luck
Post by broughton5 on Apr 18, 2014 21:01:32 GMT 1
its worth changing it but might still leak after the shafts tend to wear which cause them to weep slightly
Post by mikeley on Apr 18, 2014 22:30:08 GMT 1
Gary, you can buy a new whole shaft from Norbo for £32 if yours is really worn?
Post by mikeley on Apr 18, 2014 23:43:59 GMT 1
Forget that last post, I was getting confused with the gearbox selector shaft that Norbo sells. Sorry mate.
Post by gazbeemer on Apr 19, 2014 0:03:47 GMT 1
Thats ok mike. Took it for a spin earlier and had a little trickle come from the seal so its out now and ready for me to purchase a new one. Only this and the regulator to sort then ready for the mot hopefully.
Post by mikeley on Apr 19, 2014 6:59:09 GMT 1
Ideal, show off lol. Wish mine was ready for mot. Split the crank cases yesterday to find a main bearing that had shed one of its balls (that's what partly seized it and caused all the swarf), a worn area on the crank where the seal sits and quite a few chipped teeth+swarf in the gearbox. Luckily I have a spare complete gearbox but my spare crank has been bashed out with a hammer at some stage and bent one of the threaded ends. Some people are right butchers, lol.
Post by gazbeemer on Apr 19, 2014 7:25:12 GMT 1
Previous owner must of been a knuckle head. Ha ha. Did u see if u had a spare regulator ?
Post by mikeley on Apr 19, 2014 9:15:32 GMT 1
Sorry mate, no regulator in afraid. Try putting a post on here to ask for one?
