jord125n
New on this havnt a clue how to work it haha
Post by jord125n on Feb 22, 2014 14:36:35 GMT 1
Steering damper is 275mm off a kawasaki and the brackets are old stock made for a mk 2 I will fit later and get the pics up to shows you's, havnt seen anyone with one in yet , and hopefully it might handle better ?
jord125n
Post by jord125n on Feb 22, 2014 14:53:50 GMT 1
Post by raven13 on Feb 22, 2014 19:50:03 GMT 1
ive ridden my 125lc all summer long and even flat out (about 85)ive never thought it needed a steering damper.never had and problems with handling or steering wobble wonder if its because ive got a lot stiffer front suspension than most.
jord125n
Post by jord125n on Feb 22, 2014 20:15:08 GMT 1
Yeah my forks are very bounce and the roads I drive are canny bad surface, just to help a little bit and also for looks plus at top end I don't feel safe on it haha
Post by raven13 on Feb 22, 2014 20:35:33 GMT 1
get your forks sorted out. get some slugs made to go under the end caps to pre tension them. and add either a little more oil or some heavier oil.
