Post by rd350hybrid on Feb 21, 2014 9:38:07 GMT 1
Hello All Thought it about time to start a post on a bike I think some of you will know, RGV front and rear and a YPVS motor. (Not for the purists) but then, I don’t do stock ! Gradually stripping the bike to check what’s been done and sort out a few problems, but seem to have come across a fundamental problem with the rear wheel alignment. If the adjusters are level (equally set) the wheel is on the angle … putting a straight edge on the chain and to get this running straight, the right adjuster is almost fully back. Sooo, checked the spindle wasn’t bent, the adjusters are the same size and the spacers are all aligned, I am thinking possibly the swing arm or the frame is not aligned. Before I go further … anyone had a similar problem fitting an RGV swing arm from an M/N model Cheers Jimbo p.s. If anyone interested, this is a pic of my project I have been building for ever, similar characteristics in that its Very Loud and smokes a bit LOL
Post by Yogi on Feb 21, 2014 10:06:38 GMT 1
:PHi mate so that's where Jezes bike went? Have you got the right offset on the front sprocket? I like the Harris but 2 strokes too many for me,good luck sorting the bike.,Matt
Post by rd350hybrid on Feb 21, 2014 10:28:27 GMT 1
:PHi mate so that's where Jezes bike went? Have you got the right offset on the front sprocket? I like the Harris but 2 strokes too many for me,good luck sorting the bike.,Matt Front sprocket and chain fine, back wheel not sitting straight in the swing Arm ...
Post by Yogi on Feb 21, 2014 10:38:19 GMT 1
Sounds major,,its hard to mess it up that much!,should be straight even if off Center? Stick some pics up ,,,then start measuring things
Post by dusty350 on Feb 21, 2014 10:41:02 GMT 1
Hi Jimbo, welcome to the forum matey. you've got a couple of very nice bikes there. That Harris is a dream bike for me - would happily have that in my garage !. As for your Lc, not a common problem that I remember reading about. I would be checking that swingarm for straightness, if that's a word, and it's mounting within the frame.
Good luck
Dusty
Post by daglad on Feb 22, 2014 12:53:00 GMT 1
I love Harris's when I was a kid a geezer built one in his bedroom a little further down our street, genius, he craned it out through his window! Still it did look and sound the absolute borrox's and as an impressionable 14 year old I thought he was the second coming blatting up and down our close without a helmet on
jord125n
New on this havnt a clue how to work it haha
Post by jord125n on Feb 22, 2014 17:52:12 GMT 1
Lovely
Post by copper99 on Feb 23, 2014 17:31:59 GMT 1
Welcome mate...couple of stonking bikes there..
matt7
Post by matt7 on Feb 23, 2014 17:47:00 GMT 1
As above ^ Magnum 4 mmmmmmhhhhhh, one day Please
Post by rd350hybrid on Feb 24, 2014 19:08:25 GMT 1
Cheers Guys Lot of hours gone into the Harris, don’t want to go off topic, but heres a quick vid of one of the first fire ups after rebuild. Next step, rolling road ...told you its noisey and smokes a bit LOL
Post by alibongo on Feb 24, 2014 22:29:03 GMT 1
Super LC and also loving the 'arris.
Awesomeness from both camps eh?
Post by rd350hybrid on Feb 28, 2014 13:35:42 GMT 1
Progess at last, got the swing arm to line up and chain pretty spot on ...
One thing I am looking at is changing the pegts for a set of rearsets, any recomendations for these ?
Post by rd350hybrid on Feb 28, 2014 13:38:08 GMT 1
Are Tarozzi or Raask still available ?
Post by nikfubar on Feb 28, 2014 14:30:11 GMT 1
If you don't mind a bit of fabrication to make up mounting points, Dynamic rear sets are the dogs Got a set on both my hybrids, they come up on ebay quite often & I got both my sets for around £80.00 second hand. www.dynamicprecision.co.uk/index.shtml
dezcbr
Post by dezcbr on Feb 28, 2014 14:33:06 GMT 1
norbo has Tarozzi's in the shop look under LC trick bits
Post by rd350hybrid on Feb 28, 2014 14:45:57 GMT 1
Cheers Guys - Will follow these up
Post by rd350hybrid on Feb 28, 2014 15:02:52 GMT 1
norbo has Tarozzi's in the shop look under LC trick bits Sorry, am I missing something, can't see this on the site - Do I need to have a certain number of posts before this is visable
dezcbr
Post by dezcbr on Feb 28, 2014 15:24:50 GMT 1
Sorry have a look at rdlccrazy.co.uk its Norbos shop site. Nice bikes by the way.
Post by Norbo on Feb 28, 2014 15:50:23 GMT 1
Post by rd350hybrid on Mar 28, 2014 9:07:30 GMT 1
Quick update on progress ... not been the easiest fixes, bent swing Arm, knackered brakes, leaky carbs etc, but getting there now.
Post by rd350hybrid on Mar 28, 2014 9:10:25 GMT 1
Stll don;t have confidence in the right calliper, seems to be only pulling from one side, had them apart, blown through with an airline, seals are good, pistons all work individually, but still not pressing onto the disc evenly. Anyone had a similar problem with these Tokico brakes. ? Hopefully got a set of NISSIN's on the way, but would loke to get this sorted For the record, I am using one of these off the shop, which it says is for "This is a 5/8 mas cyl for a 350 twin disk set up" but is the piston good enough for 4 pots
Post by dusty350 on Mar 28, 2014 9:12:22 GMT 1
Hi, Shame you had the problems, it looks such a lovely bike, but at least you are winning ! I saw some NK Racing rearsets on Mouse's special the other day and they are stunning. Worth checking them out too.
Regards
Dusty
Post by dusty350 on Mar 28, 2014 9:14:58 GMT 1
Are your discs good ie. not warped ?
Dusty
Post by rd350hybrid on Mar 28, 2014 9:16:36 GMT 1
Are your discs good ie. not warped ? Dusty Ahhh, thats a bloody good idea ... will check that this evening !
Post by rd350hybrid on Mar 28, 2014 9:22:08 GMT 1
Got shot of the flappy bit of tube acting as the rear brake res ... Been after finding a use for my tiny bit of Titanium for ages LOL
Post by rd350hybrid on May 1, 2014 23:42:09 GMT 1
Anyone recomend a set of discs for RGV250 Front End, found why I couldn't get the brakes to bleed properly - buggered disc.
Hopefully this will be the last thing before getting on the road.
Post by rd350hybrid on May 1, 2014 23:44:14 GMT 1
After a lot of messing about with the Carbs, leaks, split pipes and general crap, got it running again.
Just a set of discs and ready for MOT ...
Post by rd350hybrid on May 2, 2014 17:05:27 GMT 1
Afternoon, took it up my mates engineering shop, he aligned the top mount, said it wasn't out much but when i fitted it all back went straight in.
Don't know if this was the swing arm or the frame, but it works fine now.
Not sure who did the swing arm, welds look really nice, guess I was just unlucky.
Any history on this most welcome - I seem to have lost contact with the previous owner as he was having problems elsewhere ...
Post by rd350hybrid on May 2, 2014 18:03:26 GMT 1
Are your discs good ie. not warped ? Dusty Yes your exactly right, a warped disc
Post by Eyrey1 on May 2, 2014 23:01:35 GMT 1
