paul25
Post by paul25 on Jan 23, 2014 20:52:47 GMT 1
Hiya, just after a bit of help. Was there a bracket that holds the belly pan on at the back or was it part of the frame if you know what I mean. Iam sure they didn't come from japan with tie wraps holding them on Cheers Paul
Belly pan
Jan 23, 2014 21:03:06 GMT 1
via mobile
Post by rob99 on Jan 23, 2014 21:03:06 GMT 1
There is supposed to be two brackets one either side with a m6 tapped hole in it fir you too screw the belly pan on
paul25
Post by paul25 on Jan 24, 2014 12:44:10 GMT 1
There is supposed to be two brackets one either side with a m6 tapped hole in it fir you too screw the belly pan on Thanks mate, need to try and source some now,
Post by raven13 on Jan 24, 2014 12:56:18 GMT 1
a lot of bikes have lost the tabs over the years so owners sometimes use a P-clip to secure them instead
paul25
Post by paul25 on Jan 25, 2014 10:10:22 GMT 1
a lot of bikes have lost the tabs over the years so owners sometimes use a P-clip to secure them instead May sound a silly question but what is a p clip, is it like a jubilee clip?
Post by nikfubar on Jan 25, 2014 10:37:09 GMT 1
paul25
Post by paul25 on Jan 25, 2014 15:05:16 GMT 1
haha cheers mate, thatll be why its called a p clip
Post by liffy16 on Jan 25, 2014 15:08:06 GMT 1
Bit of 3mm plate cut to size you need,weld m6 nut over 7mm hole in plate Weld plate to frame when your happy with position Better job!
