Post by badger69 on Jan 23, 2022 16:46:54 GMT 1
Hello ,Im new to the site and just wondering if these is any full gasket sets people swear by or ones I should steer clear of ? , cheers in advance ,,chris I've use Athena gasket sets on plenty of LC rebuilds with out any issues, everything fits as it should. OEB Hi do you use sealant with arthena gasket, if so what do you recommend for me a beginner. Thanks stay safe.
Post by shaunthe2nd on Jan 23, 2022 17:31:10 GMT 1
I use Athena gaskets all the time. For me, only a thin smear on the base gasket, not the head gasket. For head gasket I do one or 2 heat cycles without coolant before final torque down. Re-check after first couple of runs out. No problems so far.
Post by yamark on Jan 23, 2022 18:03:51 GMT 1
The gaskets I make and sell fit very well and are considerably cheaper than OEM. They have been tested on many road and track bikes with no issues. I even make Siamese base gaskets so you know there will be no overlap in the middle. I use Robs gaskets all the time. On a par with Gen Yam. I order the thickness I need, so get the clearances I need. He's superb to deal with, fast service and a great price. I only use Gen Yam seals, I have to use copper head gaskets for my multi- cylinder Frankenstein creations
Post by abar121 on Jan 23, 2022 23:01:25 GMT 1
I've also used Athena several times without any issues so far.
Would love to know how thick the head gaskets are compared to stock.
Post by badger69 on Mar 27, 2022 17:04:37 GMT 1
Hello ,Im new to the site and just wondering if these is any full gasket sets people swear by or ones I should steer clear of ? , cheers in advance ,,chris I've use Athena gasket sets on plenty of LC rebuilds with out any issues, everything fits as it should. OEB Hi I'm about to do my head gasket, when using Athena do you use sealant or not if yes what sealant, thanks stay safe
Post by shaunthe2nd on Mar 27, 2022 21:40:08 GMT 1
No sealant with Athena head gaskets. I fit and torque to about 90%. Then do a couple of heat cycles, no coolant. Then add coolant, torque to 100%. Another heat cycle or 2. Then re-check torque after the first couple of rides. Always worked for me. Good luck with it.
Post by chrisg on Mar 29, 2022 10:07:58 GMT 1
Ive made numerous gaskets in the past with the exception of head gaskets.
When i was 13 i had a field bike and made gaskets from cornflake boxes (read had no money) and believe it or not they worked pretty well. Used brown paper as well. Lol
Post by badger69 on Mar 30, 2022 17:45:23 GMT 1
No sealant with Athena head gaskets. I fit and torque to about 90%. Then do a couple of heat cycles, no coolant. Then add coolant, torque to 100%. Another heat cycle or 2. Then re-check torque after the first couple of rides. Always worked for me. Good luck with it. Hi thanks for quick reply, so would you say torque to 15 first then, then 17 after 2 heat cycles would be fine, what would you say is the best thing to remove any old gasket, thanks again stay safe.
Post by shaunthe2nd on Mar 30, 2022 19:02:41 GMT 1
Had to check yr numbers as you quoting ft.lbs where I use NM's but yes that sounds about right.
I carefully use a stanley blade but sideways, you can buy plastic equivalents but I've always seem to have managed without it digging in, just take your time.
Post by badger69 on Apr 1, 2022 17:28:33 GMT 1
Thanks again Shaun, will do, hope to get gasket next week, do you know if the complete Athena gasket set on ebay are genuine, thanks stay safe.
Post by shaunthe2nd on Apr 1, 2022 18:12:06 GMT 1
Thanks again Shaun, will do, hope to get gasket next week, do you know if the complete Athena gasket set on ebay are genuine, thanks stay safe. Who knows! I always go to a reputable seller. I think Norbo and Mutts both stock Athena, amongst other sellers.
Post by Tobyjugs on Apr 1, 2022 18:44:55 GMT 1
Ive made numerous gaskets in the past with the exception of head gaskets. When i was 13 i had a field bike and made gaskets from cornflake boxes (read had no money) and believe it or not they worked pretty well. Used brown paper as well. Lol That's what I used to do. I still use navigation charts when I need a paper gasket from 0.20mm
Post by Tobyjugs on Apr 1, 2022 18:52:26 GMT 1
Contrary to Shaun I will torque to full spec unless stated different in the maintenance manual. Then just like Shaun I will re-torque after a few heat cycles and check again after a bit of use, like a few months later.
If Shaun only does a few heat cycles without loading the engine I'm sure his method works.
Me I don't like to re-invent the wheel unless I have to.
Post by jon on Apr 1, 2022 19:01:05 GMT 1
We all have our own little ways of doing things. I use a combination of Tobyjugs and shaunthe2nd. I torque to full torque, but no coolant. A few heat cycles, then add fluid, check torque again. Then check torque after first run, then again at a later date after a few miles under its belt. Forgot to say this is with OEM gasket. Jon
Post by badger69 on Apr 2, 2022 15:42:18 GMT 1
Ive made numerous gaskets in the past with the exception of head gaskets. When i was 13 i had a field bike and made gaskets from cornflake boxes (read had no money) and believe it or not they worked pretty well. Used brown paper as well. Lol That's what I used to do. I still use navigation charts when I need a paper gasket from 0.20mm That's funny because that's what I did when a boy, but I preferred wheat a bix box, because I had to eat all contents before I was allowed the box, stay safe mat take care.
