Post by scott on Jul 21, 2006 22:08:33 GMT 1
this bloke was just avin a chat to his girlfreind when.........
Post by mellow on Jul 21, 2006 22:10:22 GMT 1
oi scott
Post by scott on Jul 21, 2006 22:12:59 GMT 1
what mellow ;D
Post by mellow on Jul 21, 2006 22:14:41 GMT 1
alright m8 ;D
Post by scott on Jul 21, 2006 22:20:11 GMT 1
yeah m8 ;)still ain't done me pv brakes .just met up with wiggy to give him his muddy i painted for him and he seys try tieing up the brake lever this will let all the air rise to the top of the master cylinder,so gunna give it a go.
Post by mellow on Jul 21, 2006 22:23:06 GMT 1
yep ive done this b4.............but ive also heard with it tied in for a long period it distorts the seals in the caliper so if u do it dont do it tight..........just enough to open the circuit
Post by scott on Jul 21, 2006 22:27:12 GMT 1
yeah thats what wiggy said,not to far in ;)gotta be worth a go
Post by mellow on Jul 21, 2006 22:28:19 GMT 1
has worked for me.................or u could use the other gauranteed method
Post by scott on Jul 21, 2006 22:33:22 GMT 1
what ???buy a master cylinder repair kit
Post by mellow on Jul 21, 2006 22:35:17 GMT 1
connect the hose to the caliper bleed nipple then use a piece of wire or a clamp of some sort to hold the upper end under the fluid in the reservoir
now undo the bleed nipple and pump slowly air will purge itself into the reservoir and rise to the surface never to enter the system again just keep the reservoir topped up to prevent the hose from becoming uncovered
eventually the hose becomes full of fluid and air will be seen rising up the hose to the top or bubbling out of the vent hole in the reservoir at this point you can even leave the set up to do its own bleeding and have a cup of tea
go back do it up n job done
Post by scott on Jul 21, 2006 22:38:30 GMT 1
not just a polisher r u m8 ;)cheers for that
Post by mellow on Jul 21, 2006 22:41:50 GMT 1
thats ok m8..............u can use 2 bits of hose and do both at once.......GR8 idea of MINE ;D OK IM LYIN......................cant take credit..........sum 1 elses idea n everyone who done it this way says its so simple n gr8
