Post by reluctantrd on Nov 24, 2013 21:28:31 GMT 1
Hi all. just started rebuilding an '89 F2. The dog legs - the shaft going through the swing arm - are different in length by about the width of the seal. It means that on one side I can't tighten the bolt and washer up to the s/arm. Doesn't seem right or am I missing something! Any ideas? Thanks.
Post by Yogi on Nov 24, 2013 21:39:41 GMT 1
Have you put the spacers behind the grease cups on the swing arm pivot. Sometimes they do look too long
Post by rich on Nov 25, 2013 10:17:55 GMT 1
When the dogbone nuts are tight, you should have a small gap between the large washer and the side of the swingarm. If you don't, it probably means one of the seals isn't pushed in fully.
