Post by 2strokesmoke on Nov 24, 2013 15:21:39 GMT 1
Hi after a little help please, after removing the carbs for cleaning on my lc/hybrid the cables keep pulling out of the slides?? Is there a knack to putting them in? Tried various ways but the spring/clip/retainer thing seems to let the cable pull through after a few twists of the throttle? Cheers.
Post by yamman1066 on Nov 24, 2013 18:11:01 GMT 1
hi bend the small tag down , might do some good
Post by midlifecrisisrd on Nov 24, 2013 18:33:19 GMT 1
I'll second bending the metal tang a bit.
Remove them and bend more of an angle in them and refit.
Usually sorts it
Post by 2strokesmoke on Nov 24, 2013 19:15:30 GMT 1
Cheers fellas will remove them and bend them a bit more, did give them a bit of a tweak but didnt want to go too much without making sure id not missed something thanks.
Post by manxbeater on Nov 18, 2019 21:24:23 GMT 1
anybody know where you can get the throttle slide cable retainer clips
Post by dusty350 on Nov 18, 2019 21:30:51 GMT 1
Sadly the parts are discontinued from Yamaha. Get to 10 posts and you can ask on the wanted page in the classifieds. Someone may have some spares Good luck Dusty
Post by manxbeater on Nov 18, 2019 21:59:44 GMT 1
cheers dusty.I dint know they were fitted,first ride out on my restored LC 350 it started misfiring and belching oil out from right hand exhaust. I thought oil seal had gone and was going to take engine out till i removed carb top and just cable came out.I will try and make a pair Cheers John
