gazgaz
reeds
Nov 7, 2013 23:59:35 GMT 1
Post by gazgaz on Nov 7, 2013 23:59:35 GMT 1
just fitted hy tech carbon reeds to my lc ; but cant get the reed petals to fit without any without any gaps ; any ideas please
reeds
Nov 8, 2013 1:33:11 GMT 1
Post by steve h on Nov 8, 2013 1:33:11 GMT 1
If they are just very slight gaps, they should be ok as the pressure in the crankcase will close them. Harpowa reeds had a 1.5mm gap (when correctly adjusted) between the petal and the block in their centre!
You had to readjust the gap to 1.5mm now and then when the gap had closed, with hot water and gentle bending.
PS I take it the gaps are due to the petal not sitting flush on the block?
reeds
Nov 8, 2013 12:19:31 GMT 1
Post by steven on Nov 8, 2013 12:19:31 GMT 1
Hi, I had the same problem when fitting hy tech reed petals, I tried loads of different reed blocks, but they just would not seal properly. I ended up getting new genuine Yamaha reed petals from Granby, which were approx £10 each petal. Again I had to try them on various reed blocks until I eventualy managed to get a set that sealed perfectly and rasped or quacked when I blew through them. I fitted the reed blocks using new Athena gaskets, and they leaked during pressure testing. I had to take the reed blocks back out and use hylomar on the gaskets, another pressure test showed that all was then ok. steven.
gazgaz
reeds
Nov 9, 2013 20:47:53 GMT 1
Post by gazgaz on Nov 9, 2013 20:47:53 GMT 1
thanks for the tips lads
reeds
Nov 11, 2013 18:48:55 GMT 1
Post by Bazille on Nov 11, 2013 18:48:55 GMT 1
Hi I used 600 grit wet/dry paaper on a plate glass surface and sanded the rubber sealing faces and refitted petals and there were no gaps at all-did take a while to do thou!! As above use hylomar as they do tend to warp a bit and be sure to use threadlocker on petal securing screws!
reeds
Nov 15, 2013 22:49:47 GMT 1
Post by spencerd on Nov 15, 2013 22:49:47 GMT 1
Hi, I had the same problem when fitting hy tech reed petals +1
