bruno2
Post by bruno2 on Sept 19, 2013 18:32:42 GMT 1
As the title says what do you recommend to strip the frame?
Post by shane250 on Sept 19, 2013 18:51:51 GMT 1
Are you painting it?
Post by muttsnuts on Sept 19, 2013 19:01:09 GMT 1
depends how bad it is, and what its currently painted in, dipping is my recommnedation and then a careful bead/sand blast on any areas that need it, but that assumes you have some one who can dip your frame of course !
bruno2
Post by bruno2 on Sept 20, 2013 20:29:33 GMT 1
I wouldn't say the frame was that bad but it's not good so wanted to get it back to bare metal.what are te pros and cons of paint or powder coating?
Post by shane250 on Sept 21, 2013 21:14:22 GMT 1
The reason for my first question was if its going to be powder coated then who ever coats it will sort the stripping,or they will if they are any good. There needs to be little time between blasting or dipping as rust will quickly set in. If your building a show bike then ideally its wants to be paint as paint does look nicer and marks are nowadays deducted for coating but if your going to use it then coating will wear better. I go for paint nowadays,cos i do it myself i find it hard to trust anyone else nowadays and of course black paint is cheap. I sent my Suzuki x1 frame to a local painter and nearly came to blows when he wanted paying for this... so i took it home and a few hours in the garage produced this.... My advice would be to use someone who comes recomended for paint or coating,or do it yourself.
Post by daveo on Sept 21, 2013 22:02:13 GMT 1
£uck me Shane, that is $hite - no wonder you nearly came to blows. If I was doing mine again I'd go for paint - powder coat chips really easily, just a dropped screw pinged a nice chunk off it.
Post by shane250 on Sept 21, 2013 22:12:18 GMT 1
The best of it is this guy earns a living from painting,how i really dont know.I would never consider myself as a painter but i can paint. You certainly need to be on your toes nowaday For me.. Paint = ME powder coating LSN coatings wakefield. www.lsn-coatings.co.uk/90270/info.php?p=4
Post by dusty350 on Sept 22, 2013 11:14:01 GMT 1
