Post by dave1967 on Sept 3, 2013 11:33:03 GMT 1
Have got R1 callipers and standard LC2 master cylinder..been trying to bleed up for 2 hours..all air is out..pistons fluctuate slightly but just wont push pads out..getting really pissed off now..any ideas??
Post by brownsauce on Sept 3, 2013 11:44:48 GMT 1
Have you tried pushing the oil up from the caliper with a syringe, worked on mine although mine is standard. Might be worth a try Or leave it to stand for a day or two sometimes works. Good luck.
Post by muttsnuts on Sept 3, 2013 11:56:17 GMT 1
might be your master cylinder, sounds like its either got air trapped or is not travelling enough to bleed properly.
Post by copper99 on Sept 3, 2013 12:21:31 GMT 1
Lever cable tied to the bar overnight has helped me in the past..or as MN says, id be looking at rebuilding the MC.
Post by steeley on Sept 3, 2013 12:37:53 GMT 1
could be the m/cylinder ratio is wrong for the new calipers.
Post by copper99 on Sept 3, 2013 12:57:17 GMT 1
could be the m/cylinder ratio is wrong for the new calipers. I was going to say that but I assume this is a well used, known modification?
Post by oldelsieboy on Sept 3, 2013 13:01:48 GMT 1
could be the m/cylinder ratio is wrong for the new calipers. I was going to say that but I assume this is a well used, known modification? Standard R1 master cylinder is 14mm bore, LC2 is 5/8" OEB
Post by dave1967 on Sept 3, 2013 15:00:00 GMT 1
Have just got bled up working perfect..had to strip master cylinder and found the rubber seal had twisted on top of spring..is this common??
Post by steeley on Sept 3, 2013 17:37:30 GMT 1
dave ,glad to hear you have got it sorted out .cant say have heard of a twisted seal. have seen damaged seals and damaged cylinders.
