Post by youngrider95 on Aug 21, 2013 17:02:15 GMT 1
i recently brought a 1987 rd 125 ypvs with a re-built engine and its knocking on each stroke of the piston and keeps cutting out, just wounding because its re-built does the carb need setting up again would like a second opinion thanks
dpayne
Post by dpayne on Aug 21, 2013 21:21:25 GMT 1
Did you get it from Wolverhampton ?
Post by muttsnuts on Aug 21, 2013 22:02:01 GMT 1
could be the piston hitting the head or head gasket, carb wise they can be temperamental as well
Post by youngrider95 on Aug 22, 2013 8:43:22 GMT 1
Thanks for the help much appreciated and yes I did get it from Wolverhampton
Post by Norbo on Aug 22, 2013 8:56:42 GMT 1
Well if its rebuilt its not big end knocking so id tend to think top end as already said piston hitting head gasket may me remove the plug shine a torch down the plug hole and look at the piston crown see if its got a silver ring around the piston top for hitting something .
Post by youngrider95 on Aug 22, 2013 10:20:24 GMT 1
Ok thankyou and I out to for a ride and notised u blew up my front and rear indicators and it has done the 3 times now, would u have advise?
dpayne
Post by dpayne on Aug 22, 2013 12:32:14 GMT 1
yes it is the top end i had a look at this one. you will need to do the top end which is not a big job.
