Post by muckyal on Aug 9, 2013 11:57:56 GMT 1
ok... posted my f2 feels down on power. just not as I remembered from yrs ago and struggles to hit 100mph. ive been advised people prefer 31k carbs rather than powerjets. so...my carbs are adjusted fine. powervalve all set correct. engine sounds sweet enough. no temperature issues. my question is....is it possible to blank off the powerjets and fit 240 mains to carbs I have or are there differences elsewhere that wont allow this? also would I need to alter oil pump if this is possible? my f2 has standard air filter and pipes.
Post by garyt on Aug 9, 2013 19:25:22 GMT 1
has it got std sprocket on 17 front 39 rear, i used to run mine with 16 front for more acceleration less top end
Post by The Pirate on Aug 10, 2013 10:35:31 GMT 1
has it got std sprocket on 17 front 39 rear, i used to run mine with 16 front for more acceleration less top end thats the way I want mine to be set up when its eventualy on the road
Post by muckyal on Aug 10, 2013 10:57:49 GMT 1
hi thanks for reply but its not that quick on acceleration either! just had another issue im about to post about!!!!!
