stuboy
Post by stuboy on Jul 5, 2013 15:29:49 GMT 1
If using a genuine Yamaha RD350LC head gasket do I need to use any jointing compound ?
Post by billyboy on Jul 5, 2013 15:44:14 GMT 1
have always used a thin film meself
Post by Yogi on Jul 5, 2013 18:07:44 GMT 1
I never have
Post by steeley on Jul 5, 2013 18:36:21 GMT 1
even with pattern gaskets have never used sealant on a head gasket.i have forgot to give them the final torque so when I filled the rad up the gasket leaked, but fixed with another nip down.
stuboy
Post by stuboy on Jul 5, 2013 20:13:42 GMT 1
cheers guys will assemble the yammagammas top end tonight with no jointing compound
Post by arrow on Jul 5, 2013 20:27:24 GMT 1
None for me either.
phil38
Post by phil38 on Jul 6, 2013 17:53:19 GMT 1
No. Clean and dry.
Post by bare on Jul 6, 2013 18:21:47 GMT 1
Permatex Copper coat HG spray OR Rattle can Laquer (no substitutes ;-)..Clear or the colour of yer choice. It Works.. period. Also ideal for repeated HG reuse.. if..the gasket is of metal.
Post by yardstikk on Jul 10, 2013 16:55:09 GMT 1
I always go for Gen Yam head gaskets and dont use sealant..Never had a leaker yet..
Post by ngordoncrosby on Jul 11, 2013 6:56:23 GMT 1
I tried with and without sealant and it leaked was,nt till I gave the head a light plane that cured the problem.I think the other thing is not to forget to give it a second torque up once its been ridden
Post by looey on Jul 11, 2013 7:19:22 GMT 1
Permatex Copper coat HG spray OR Rattle can Laquer (no substitutes ;-)..Clear or the colour of yer choice. It Works.. period. Also ideal for repeated HG reuse.. if..the gasket is of metal. Is that also the same for a YPVS 350 metal head gasket ?. If so, any chance you could put a link up to the exact correct ones of these to use, as I'm just about to try to re-use a genuine head gasket I found the Permatex Copper Coat but I can only find it in the US and they won't ship it to the UK ?. Cheers
Post by kevsypvs on Jul 11, 2013 12:10:44 GMT 1
never used any gasket sealant on head gaskets , not required
