Post by flames on Jun 28, 2013 9:10:13 GMT 1
hi all,just wandering what gearbox oil u all use? i used castrol power1 4t gps10w 30 before,and found it to be very good,and had no clutch slip.castrol reccommend their mtx part synth.80w. is their any advantage to using this over what i used before? or does anyone have any other reccommendations worth looking at? cheers
Post by Delbert on Jun 28, 2013 13:55:31 GMT 1
I used to use a 10/40 semi syn oil.before someone on here suggested a light gear oil was good , so I use a 75 /90 now witch seems a lot smoother through the gears ,, others have said a good atf fluid works well ,
Post by bare on Jun 29, 2013 3:30:07 GMT 1
75/90 GL4 oil is Great. ATF works, but it is hard on the bearings
Post by flames on Jun 29, 2013 13:12:56 GMT 1
thanks peoples.
paulo
Post by paulo on Jun 29, 2013 19:55:18 GMT 1
Just put some Halifords own two stroke wet clutch 10 - 40 oil in @ just over £6 a litre because was going to drop oil after a couple of hundred miles after my engine rebuild and replace will decent stuff. But after 150 miles, no clutch slip and neutral when running, I'm having second thoughts.
Post by flames on Jun 30, 2013 13:30:03 GMT 1
nice one.i used the stuff i drained for now,coz was only in there for around 100 miles.will see what gives,and maybe try the halfords bargin bucket next time.
