Post by mudguts on Jun 17, 2013 18:10:15 GMT 1
Hi Does anyone know if you can take the RD125LC mk3/tzr clocks apart and clean the inside of the clock glass face, as mine has a slight haze on it and it could do with a clean, there are 2 small screws on the back of each, rev counter and speedo. thought i would ask first before i end up with disaster,
thanks mudguts
Post by museumman on Jun 19, 2013 20:30:40 GMT 1
You need to prise off (slightly damaging) the glass surround (black metal bit) from the back with a small thin screwdriver (electrical screwdriver or similar). Bit by bit all the way around, then you can pop off the glass. The surround will now look nibbled at, you have to then seal it back with a blunt ended tool and hammer. It's annoying, as I've got some nice low milers with a little bit of haze, and you can see the swirl in what looks like the factory workers last going over with a cloth.
Post by gazlad on Jun 19, 2013 21:22:36 GMT 1
Did mine with great results, best to strip the casing, loom and temp gauge to release the clocks, not forgetting the tiny Philips screw in the trip knob, I then nibbled the black metal rings off with some small long nose pliers, the slower the better, this then real eases the seal and the glass plus workings so you can give it all the full service & clean, reassembly is the opposite and I made a small tool to roll the lip back over the clock , ten re zinced the housing fittings and black polished the casings, a few pics before and after, hope this helps??
Post by mudguts on Jun 20, 2013 6:31:31 GMT 1
Thanks for that! im after the top plastic bit with the cherry lights too, mine is broken by the ignition switch,
Post by gazlad on Jun 20, 2013 9:30:01 GMT 1
Of you want new, cmnsl had one £56
Post by mudguts on Jun 20, 2013 13:41:38 GMT 1
£56 is a lot of loot for that
Post by gazlad on Jun 20, 2013 23:13:08 GMT 1
You won't get new cheaper !!
Post by mudguts on Jun 21, 2013 7:56:54 GMT 1
The speedo and rev counter are near mint apart from a swirl on the speed glass inside, i will have to keep a lookout on ebay etc, perhaps a forumite may be able to help, i got a mint tail fairing for £25, the clocks only cost a tenner, thanks for the advice and pics on the cleaning, if i cant find one by xmas i will remove mine and try to refurb it.
thanks
Post by museumman on Jun 21, 2013 21:43:59 GMT 1
I can break a nice set of clocks if I get some offers for the bits.
Post by 17 Again on Jun 25, 2013 19:04:47 GMT 1
sorry to butt in,
am i safe to pull out the trip counter knob to sawp for another set of clocks i have? don't want it to break it.
Post by museumman on Jun 25, 2013 19:56:45 GMT 1
No, theres a tiny screw in there. Be careful not to round it off.
Post by 17 Again on Jun 25, 2013 20:00:21 GMT 1
thanks for the tip.
i had no idea.
Post by gazlad on Jun 25, 2013 21:06:08 GMT 1
As per my earlier clock post ....
