Post by dave1967 on Jun 16, 2013 22:17:51 GMT 1
Firstly what holds back brake lever on..does it just slot over and held by master cylinder...where do i fit the rear brake light sensor and what holds the black plastic headlight bowl on..on the outside of the headlight bracket there seems to be little indents for something to clip into..ive looked everywhere and cant find anything that looks as if it will do the job..ill take pics in a bit to show what i mean.
Cheers
Dave
Post by soccersmyth on Jun 16, 2013 22:28:09 GMT 1
Twud help.
Them we might know what bike it is too
Post by copper99 on Jun 16, 2013 22:39:36 GMT 1
Twud help. Them we might know what bike it is too You'll get all the help you need on here anyway OP ..
Post by dave1967 on Jun 17, 2013 2:19:32 GMT 1
Thats the headlight bit..what do i use to bolt it on? Ignore the pring im getting a new one..but is this correct?Cant work out where the rear brake light sensor goes. Im guessing this bit goes on the handle bars..trouble is it wont slide over because bars have been powder coated..any ideas? Cheers in advance.....its an LC2 by the way
Post by Shytalk on Jun 17, 2013 12:01:55 GMT 1
Dave, heres my F1 - same layout You should be able to make out the rear switch on the right with 2 wires coming off it, basically there is a circular metal plate that the switch clips into behind the frame tube, the spring end then attaches to the other hole mount on the brake lever. The clutch perch, you will need to gently prise it open to get it over the bars, a little grease or WD40 will help too. The headlight bolts onto the frame with 2 nut and bolt combinations, and there should be a couple of rubber grommets pear shaped around the hard white plastic of the shell too.
