Post by liffy16 on Jun 15, 2013 19:20:33 GMT 1
been having problems with throttle cables on my 350ypvs n1 when closing throttle revs are not dropping sometimes resulting in cables sticking flat out.narrowed it down to the 3way splitter tryed another new pattern cable and this seems worse.anyone had same issues and will a geniune cable cure this?are lc and ypvs the same
Post by midlifecrisisrd on Jun 15, 2013 20:01:32 GMT 1
Pattern cables should be avoided although I think Norbo does good copies.
Post by pepsisteve on Jun 15, 2013 20:06:58 GMT 1
I f**ked about with mine when built it with a new pattern cable on it for a week, put the old knackered one on it and it cured the problem straight away, however I brought another make pattern cable and it wad fine
Post by steeley on Jun 15, 2013 20:09:07 GMT 1
check the spliter ,there should be a plastic disc that holds the cables .sometimes this is loose and the cables can wander?
Post by liffy16 on Jun 15, 2013 20:44:32 GMT 1
check the spliter ,there should be a plastic disc that holds the cables .sometimes this is loose and the cables can wander? plastic disc was loose put that back still no good arghhh!
Post by nikfubar on Jun 15, 2013 23:40:23 GMT 1
Throw the pattern cable in the bin NOW they're dangerous, even if you can get it work ok it's just as likely to stick in the fully open position when your riding the bike, I know from experience If you cant find a genuine one Norbo sells good patten ones failing that if you have an old OEM one & send it to Venhill they will make you a new one
matt7
Post by matt7 on Jun 16, 2013 9:54:50 GMT 1
Likewise pattern YPVS cables - they stretch
Post by bryan on Jun 16, 2013 12:04:58 GMT 1
I fitted a new Genuine one to my LC and never had any probles. Kept the one I took off which was a patten one and stuck it on the YPVS LC when I built it as it worked fine, been on it 3 years now and been perfect. However if you can strech to it, get a Gen Yam one.
Post by nikfubar on Jun 16, 2013 12:22:38 GMT 1
You must have had a good quality pattern one then as the majority are rubbish
Post by bryan on Jun 16, 2013 12:40:46 GMT 1
Ive always been surprised to not have a problem with it, It was on the bike when I got it in 2006, Ive lubed it now and again and its been fine. As I needed to buy one for the YPVS LC,Ithought I would give it a try, and dont see the point in paying about £80 for another one while it works. Never had problem getting carbs balanced and getting oil pump adjusted correctly. I have no idea who made it.
Post by liffy16 on Jun 16, 2013 14:14:10 GMT 1
Throw the pattern cable in the bin NOW they're dangerous, even if you can get it work ok it's just as likely to stick in the fully open position when your riding the bike, I know from experience If you cant find a genuine one Norbo sells good patten ones failing that if you have an old OEM one & send it to Venhill they will make you a new one okay some great feedback going to get a geniune lc cable should fit a valve okay,but agreed cheap pattern cables are dangerous
Post by bryan on Jun 16, 2013 16:54:39 GMT 1
Bugger, got to take my own advice now as a strand has broken on my oil pump cable and its not returning as it should.
Post by steeley on Jun 16, 2013 18:20:58 GMT 1
buy some cable making kit and make your own.have made a few for my own plus some specials.
Post by Deleted on Jun 16, 2013 21:13:33 GMT 1
I bought one of Norbo and it has, and is still working fine. The only thing I did was make sure it was well lubed before fitting.
Post by bryan on Jun 16, 2013 21:28:10 GMT 1
Turns out it was bit of a larger problem, the part of the threaded adjuster that pushes againts the outer cable had worn away and the cable had slid about 10mm further in and oil pump inner cable was overly slack and way short of the oil flow there should be. Had a Gen Yam F2 cable with knackered throttle end, so stripped it an swapped the oil pump cable. Sorted! Just got price for a new LC throttle cable and its £86 now! As its working it can stay as it is.
Post by Norbo on Jun 18, 2013 17:48:27 GMT 1
I stopped doing paten cables from the hole saler years ago, I had all my cables made in japan by the place that makes them yam or did make them for yam any way .
Post by bryan on Jun 18, 2013 21:08:12 GMT 1
What I did notice with the genuine one was the cable ends are very secure in the splitter, so they dont pull out leaving the sliders up and bike reving its tits off.
Post by watchhislegs on Jun 18, 2013 21:23:27 GMT 1
Post by petejw22 on Jun 19, 2013 13:30:48 GMT 1
Genuine every time. Why take the risk?
Post by fatfredfaefife on Jun 19, 2013 14:32:29 GMT 1
Genuine for me as well, I bought a pattern one (can't remember where from) but no end of problems dumped it and fitted a genuine cable.
