Post by midlifecrisisrd on Jun 15, 2013 17:36:08 GMT 1
And so starts this years craving for more power. Was lean on the dyno at the top end so upped 2 sizes but dropped the needle a bit. Fitted some Banshee race coils to replace the 30 year old original And had a nightmare fitting the V force 4 reeds. Not them that caused the problem but wanted to stick with 10mm spacers to get as long an inlet as possible and clear the boost port. Problem is that as well as spacing back due to the angle of the barrels it also moves them up meaning the cable elbow clashes with the frame and stops them fitting. Heated up the elbows and bent some more which helped a little but ended up taking 2 - 3mm off the carb top where the adjusters screw in. Still tight but now fit. Ended up fitting a steering damper as could be a bit lively over anything other than a billiard table. Nice fit, tucks in nicely so no damper rod poking your knee. Really pleased with the RZR Jap spec painted tank. Was going to be my spare but now my favorite. And then to make it look faster put on a billet oil pump cover Been a busy couple of days, can you tell my wife is away? Steve
m1ke
Post by m1ke on Jun 15, 2013 17:40:49 GMT 1
I'd be interested to see how much gain the v force 4's give back to back. Must be more with the larger carbs anyway...
Post by midlifecrisisrd on Jun 15, 2013 17:45:26 GMT 1
I'd be interested to see how much gain the v force 4's give back to back. Must be more with the larger carbs anyway... Only got last years dyno run to compare but not really a good comparison as jetting changed and I was running TZR 250 cages before. Steve
Post by copper99 on Jun 15, 2013 17:46:24 GMT 1
Thats a beautiful bike mate, good luck with the quest for power!
Post by Delbert on Jun 15, 2013 17:48:15 GMT 1
Awesome steve !! Looks the biz
Post by midlifecrisisrd on Jun 15, 2013 17:58:50 GMT 1
Will be happy if I can get 75 - 80 rwhp Steve
Post by wallcraft on Jun 15, 2013 22:23:26 GMT 1
Steve, were did you get the 10mm spacers as I need some. Awesome machine. Mark.
Post by midlifecrisisrd on Jun 15, 2013 23:00:16 GMT 1
Steve, were did you get the 10mm spacers as I need some. Awesome machine. Mark. Got them from Nigel at NK racing Steve
Post by steeley on Jun 16, 2013 5:41:46 GMT 1
nice bike ,the pipes are they chrome or stainless.
Post by icarus001 on Jun 16, 2013 9:30:24 GMT 1
I need to stop reading threads like this, just as I decide to stop trawling the internet for parts to custom my LC I see a special like this and change my mind again. That looks very nice and still inkeeping with the lines of the original bike. 75 rwbhp!!! That would be impressive.
Post by midlifecrisisrd on Jun 16, 2013 11:44:43 GMT 1
nice bike ,the pipes are they chrome or stainless. Stainless from Kenny at TSA Steve
Post by midlifecrisisrd on Jun 16, 2013 11:52:18 GMT 1
[/quote] I need to stop reading threads like this, just as I decide to stop trawling the internet for parts to custom my LC I see a special like this and change my mind again.
That looks very nice and still inkeeping with the lines of the original bike. 75 rwbhp!!! That would be impressive. [/quote]
You will soon learn there is no end, there will always be something else you want.
Hopefully 75 should not be that difficult, running a tad over 73 just now and was running lean.
Just had it out for a test, fueling seems good. No stuttering on neutral throttle and a lot happier on the motorway holding 7 - 8k.
Now revving clean all the way through and has a habit of bouncing of the 10.5k rev limiter with no power tail off so seems better.
Post by icarus001 on Jun 16, 2013 14:57:11 GMT 1
You will soon learn there is no end, there will always be something else you want. I know, but overall I've decided to keep the LC for what it is. I know there are a lot of improvements I could make but ultimately I could just buy a CBR600RR if I wanted that sort of power, they weigh about the same as an LC as well. Saw a new Triumph 675 naked bike today, looked very nice. Doesn't stop me admiring the specials and yours looks very very nice, but I think I'll keep my LC more or less stock....at least until I'm tempted by more pictures....
