Post by dave1967 on Jun 13, 2013 1:35:50 GMT 1
Spent half the night trying to fit shocker on LC2..i firstlt put top shock bolt in then couldnt get bottom H piece to fit and now ive got top one in but cant get bottom H piece in..also i have new doglegs off NK racing and new bushes but they are tight as tight and i can hardly move them..will they bed in ok?
Post by Tone on Jun 13, 2013 5:45:29 GMT 1
When I greased the bushes on mine I found it easier to locate the H piece and put the lower shock bush and bolt in first then either get someone to lift the rear wheel up so you can get the top shock bolt in or put a piece of wood under the rear wheel to lift it up. Once all the bolts were in I went over with a torque wrench to tighten to spec.
Post by dave1967 on Jun 15, 2013 1:56:20 GMT 1
Thanks fot that lifted rear wheel and it went straight in..where do i find all the torque settings?
Post by Tone on Jun 15, 2013 6:24:55 GMT 1
The torque settings are shown here : www.rd350lc.net/WM31K-6.pdf Shown on page 6-54 of the manual The torque setting for the top shock bolt is 40Nm or 28 ft-lb
Post by dave1967 on Jun 15, 2013 10:01:20 GMT 1
Thanks for that..great help
