Oil pump
Jun 12, 2013 14:50:17 GMT 1
via mobile
Post by mattyd04 on Jun 12, 2013 14:50:17 GMT 1
Can any one tell me how you know the difference between a 350 and a 250lc oil pump
Thanks , matt
Post by Roofmonster on Jun 12, 2013 15:29:59 GMT 1
The 350 pump has a yellow dot and the 250 has a red dot. Other than that you have to remove it and count the turns on the worm drive. 5 turns for a 350lc pump 7 turns for a 250lc pump
Someone correct me if I'm wrong If you ask Arrow on this forum he will identify it - he is the guru of oil pumps
Oil pump
Jun 12, 2013 16:26:06 GMT 1
via mobile
Post by mattyd04 on Jun 12, 2013 16:26:06 GMT 1
The 350 pump has a yellow dot and the 250 has a red dot. Other than that you have to remove it and count the turns on the worm drive. 5 turns for a 350lc pump 7 turns for a 250lc pump Someone correct me if I'm wrong If you ask Arrow on this forum he will identify it - he is the guru of oil pumps Cheers for that I will have a look Thanks, matt
Post by arrow on Jun 12, 2013 16:38:48 GMT 1
I am just about to post on a simple check that avoids taking the pump off. In the advice section.
Edit; Done.
