Post by PhilR on Jun 11, 2013 22:52:55 GMT 1
Hi
Does anyone know what type of plug caps I should use on a Power Valve? the plugs are BR9ES R rated, which think means it has a resistor.
thanks
Post by bryan on Jun 12, 2013 0:16:44 GMT 1
Post by Bozzy on Jun 12, 2013 1:06:51 GMT 1
Hi Does anyone know what type of plug caps I should use on a Power Valve? the plugs are BR9ES R rated, which think means it has a resistor. thanks I am running BR9ES but not R rated?. Should I have the resistor type?.
Post by Tone on Jun 12, 2013 5:53:35 GMT 1
If you're using BR9ES these are the resistor type.
paulo
Post by paulo on Jun 12, 2013 18:18:15 GMT 1
Resistor or non resistor type plug caps will do, just fit the correct spark plug to suit - BR for your non resistor plug caps & B for your resistor plug caps I've got resistor plug caps fitted and have run both types of plugs with no problems !.
Post by nikfubar on Jun 12, 2013 18:37:31 GMT 1
I use these aswell the hard plastic ones seem to self distruct internally
Post by PhilR on Jun 12, 2013 18:49:17 GMT 1
Great thanks for the info guys
