Post by Ragger rd on Jun 9, 2013 22:59:24 GMT 1
I have brand new crank cases no numbers,but have the security lines,do I get them restamped or leave as is.the way I see it is engine is worth more as is,wats your opinions
Post by marsbar350 on Jun 9, 2013 23:03:57 GMT 1
I have brand new crank cases no numbers,but have the security lines,do I get them restamped or leave as is.the way I see it is engine is worth more as is,wats your opinions you need the right font if restamping.any dodgy stamps are a no no
Post by Ragger rd on Jun 9, 2013 23:06:33 GMT 1
My mate owns a Yamaha dealership in poole so if I did get done would be done properly,where would I stand if I did not get them done,in my eyes these cases are rare as hens teeth?
Post by bryan on Jun 9, 2013 23:42:58 GMT 1
all jap imports have no engine numbers, so not a problem. Better with no restamping.
paulh
Post by paulh on Jun 10, 2013 19:36:35 GMT 1
Will always look slightly dodgy if they have been stamped (even though they are not).
Post by 47x on Jun 10, 2013 21:19:34 GMT 1
jap imports DO have the first 3 numbers(the code for that model)on the crankcases,but i would leave them blank chap,,imo
m1ke
Post by m1ke on Jun 10, 2013 21:26:47 GMT 1
I'd have them stamped, a matching numbers bike is worth more than one that isn't/ and you won't want to be stamping them once fitted to the bike.
Theyre only worth lots when not fitted to something...
Post by oldelsieboy on Jun 10, 2013 21:30:40 GMT 1
I'd have them stamped, a matching numbers bike is worth more than one that isn't Wouldn't that be classed as a "re-stamp" tho? Selling a bike as matching numbers when in theory its not. I would class that as fraud. Just my tuppence worth. OEB
Post by Yogi on Jun 10, 2013 21:38:04 GMT 1
I've got one with new cases and I wouldn't touch them,,as marsbar said ,if there done wrong they will look suss to any buyers
Post by Ragger rd on Jun 10, 2013 21:40:15 GMT 1
ok cheers for advice guys
Post by bryan on Jun 10, 2013 21:42:06 GMT 1
I'd have them stamped, a matching numbers bike is worth more than one that isn't Wouldn't that be classed as a "re-stamp" tho? Selling a bike as matching numbers when in theory its not. I would class that as fraud. Just my tuppence worth. OEB You cant restamp them as there could well be an engine out there somwhere on a bike with those numbers
m1ke
Post by m1ke on Jun 10, 2013 21:55:10 GMT 1
Wouldn't that be classed as a "re-stamp" tho? Selling a bike as matching numbers when in theory its not. I would class that as fraud. Just my tuppence worth. OEB You cant restamp them as there could well be an engine out there somwhere on a bike with those numbers Not if you are using the new cases to swap out for a set of broken or damaged cases....
paulh
Post by paulh on Jun 11, 2013 12:00:44 GMT 1
Got to admit it i was buying i wouldnt touch anything with restamped numbers.
Also makes it non complient it it was ever to be raced.
Post by winnerevo1 on Jun 11, 2013 12:10:29 GMT 1
How would you know that it's been re-stamped if the correct font stamps were used? 4L0 cases were stamped by hand.....
paulh
Post by paulh on Jun 11, 2013 12:33:16 GMT 1
Suppose if it was done properly you wouldn't tell, but restamping I've seen examples of has been pretty amateurish or obvious.
Post by Ragger rd on Jun 11, 2013 17:00:50 GMT 1
the old cases were damaged due to chain snapping,so no one is riding around with numbers,
