Post by hopper350 on Jun 7, 2013 23:21:04 GMT 1
Does anyone sell the perspex disc for the clutch side case convertion on its own, I have a o-ring kit and milling the cover out is managable. hopper
Post by Roofmonster on Jun 7, 2013 23:25:23 GMT 1
Ask Norbo - he may be able to help you. I know he does a DIY kit but it includes all the parts for the conversion.
Post by skydemon on Jun 8, 2013 4:07:50 GMT 1
Or Nigel at NK racing :-)
Post by alext on Jun 8, 2013 7:21:56 GMT 1
i think I have a couple of these that are about 1mm too big in diameter - simple to sort if you have access to a belt sander.
pm me if your interested and I'll go look for them.
Post by gazlad on Jun 8, 2013 10:21:07 GMT 1
Or buy a piece of 8mm lexan, a trick cover of Norbo. Draw around the cover on the lexan, jig saw it out job done. LEXAN EXELL*D SHEET 8MM CLEAR 297mm x 210mmA4 on eBay £5
Post by alext on Jun 13, 2013 13:25:43 GMT 1
other interesting bit of info for this....
draw around an old CD - then cut to the inside of the line.
its a perfect fit.......
Post by alext on Jun 14, 2013 17:50:54 GMT 1
Ive found these, and as I thought there are 2 of them, so one is spare for the postage if anyone wants it.
it needs 1mm taken of the outside diameter of the plastic.
Post by midlifecrisisrd on Jun 15, 2013 11:23:00 GMT 1
Ive found these, and as I thought there are 2 of them, so one is spare for the postage if anyone wants it. it needs 1mm taken of the outside diameter of the plastic. How thick is the lexan? May be interested Steve
Post by alext on Jun 15, 2013 15:37:18 GMT 1
its 4mm as far as I remember.
Post by midlifecrisisrd on Jun 15, 2013 17:10:56 GMT 1
its 4mm as far as I remember. Already have a 4mm one, was looking for a thicker one. Got some 6mm lexan but just lazy. Thanks anyway, Steve
Post by nikfubar on Jun 15, 2013 18:59:08 GMT 1
Or buy a piece of 8mm lexan, a trick cover of Norbo. Draw around the cover on the lexan, jig saw it out job done. LEXAN EXELL*D SHEET 8MM CLEAR 297mm x 210mmA4 on eBay £5 That's what I did, but didn't bother with O rings, just made a paper gasket & it seals fine with a smear of RTV silicone
Post by alext on Jun 17, 2013 11:17:37 GMT 1
I havent found a problem with the 4mm....
Why do you want thicker?
Post by midlifecrisisrd on Jun 18, 2013 0:27:48 GMT 1
I havent found a problem with the 4mm.... Why do you want thicker? mine uses a rubber gasket so no o rings and has split at all 3 fixing points. just want to make mine a bit tougher. steve
Post by alext on Jun 18, 2013 9:46:56 GMT 1
mine has no o-ring either, just a seal of instant gasket - no leaks and no splits.
