kevbn2
Post by kevbn2 on Jun 7, 2013 20:55:02 GMT 1
Post by cb250g5 on Jun 7, 2013 21:28:15 GMT 1
Post by Delbert on Jun 7, 2013 22:13:45 GMT 1
Mine was like that , bit of 320 wet & dry with some wd40 to take ant high spots off Some will say nay
Post by Deleted on Jun 7, 2013 22:27:53 GMT 1
Mines a little bit like that... Be interesting to see the opinion on this.
Post by crash on Jun 7, 2013 22:43:45 GMT 1
get the wet and dry paper onto it
Post by majortom on Jun 8, 2013 0:27:57 GMT 1
It looks like the piston has given its self up to the god of speed? As long as the sealing face is okay, just clean it up with wet and dry and rebuild it, Check for cracks
Post by bryan on Jun 8, 2013 3:16:38 GMT 1
I've seen worse used, however get it off to someone like Bob Farnham/ Mick Abbey and get it reprofiled and skimmed for better compression and narrower squish, as standard they are high on the volume and too wide on the squish.
Post by bare on Jun 8, 2013 3:17:40 GMT 1
Find a 'decent' Moto machinest anfd have then reprofile the comb chamber and match the squish band to the curve of your pistons. Setting comp and squish clearance at the same time. Well worth doing. Typical cost (on this side of the Atlantic) is ~$100 Not gbps :-).
Post by bryan on Jun 8, 2013 3:37:16 GMT 1
About £60ish here.
Post by Norbo on Jun 8, 2013 10:18:51 GMT 1
like most have all ready said , just sand it down it will be fine a lot look like that .
Post by steve h on Jun 8, 2013 12:45:08 GMT 1
I've seen worse used, however get it off to someone like Bob Farnham/ Mick Abbey and get it reprofiled and skimmed for better compression and narrower squish, as standard they are high on the volume and too wide on the squish. x2
Post by bryan on Jun 8, 2013 16:19:51 GMT 1
mind you, Im not one to speek, got a head Glyn machined to 21cc and O ringed for no head gasket and still not put it on after having it done in 2010!
