Post by copper99 on Jun 3, 2013 14:48:07 GMT 1
Been away for a week or so with the kids and Mrs to sunny Spain , I think the weekends have been warmer here than where i was but moving on to more important matters.. I moved the LC out of the garage and noticed this oil leak (approx 8cm in dia) on some card id left underneath the bike, seems like fresh 2 stroke oil is making its way to the bottom of the crankcases. Its taken 10 days to get like this , so I wasnt overly concerned , the lines are full and she smokes well enough(as confirmed by the Yamaha dealer I went to this afternoon) I was expecting there to be a drip from the lines but taking the cover off its all dry as a bone under there, nothing is leaking onto the top half of the crankcase from any of the tubing and dripping thru... Any ideas as to how its making its way to the lower crankcase? Thanks [a href=" |http://thumbsnap.com/bdFqrMQL"] |http://thumbsnap.com/bdFqrMQL[/a] [a href=" |http://thumbsnap.com/sxfxOqs9"] |http://thumbsnap.com/sxfxOqs9[/a] [a href=" |http://thumbsnap.com/w7VqwIlH"] |http://thumbsnap.com/w7VqwIlH[/a]
Post by copper99 on Jun 3, 2013 14:48:43 GMT 1
So good I entered the pictures twice.....like the new look forum by the way..
Post by willbloke on Jun 3, 2013 14:53:05 GMT 1
You sure it's 2T ? Leak from manifold ?
Or , slight weep from gearshift shaft seal ?
Post by copper99 on Jun 3, 2013 15:01:48 GMT 1
Its defo fresh red 2 stroke oil, you can see it between the two crankcase stud nuts in the pic above
Further forward you can see the usual black gunk from the headers as well.
Gearbox oil in my bike is yellow
Post by oldelsieboy on Jun 3, 2013 15:15:06 GMT 1
Check around the bottom of the reed valve gaskets. Had a similar issue awhile back when bike was stood for a while. 2t had soaked through gaskets dripped onto crankcase & through the drain hole behind the barrels.
OEB
Post by billbott on Jun 3, 2013 15:19:22 GMT 1
Watching this thread - mine does exactly the same and has done for 6 years!!!!
Post by copper99 on Jun 3, 2013 15:30:06 GMT 1
Check around the bottom of the reed valve gaskets. Had a similar issue awhile back when bike was stood for a while. 2t had soaked through gaskets dripped onto crankcase & through the drain hole behind the barrels. OEB Bingo ! Thanks mate. Just run a finger under the them and the LH side was covered underneath. New gaskets where fitted but there you go. is the bike safe to run like this for a short period?
Post by copper99 on Jun 4, 2013 16:11:57 GMT 1
Nipped the reed block up last night, just checked and its still leaking...
..sadly it also seems the oil pump is well worn so I need a new one, I know arrow comes recommended but i want a pump like yesterday..
Post by Roofmonster on Jun 4, 2013 17:23:29 GMT 1
The non return valves in your pump are probably letting the oil syphon form your tank whilst it's parked up. I can fully recommend Arrow's oil pump referb - they come back like new. His turn around is pretty quick on them too. PM him and ask - he's a really nice guy to boot!
Post by skydemon on Jun 4, 2013 18:43:29 GMT 1
Arrow is quick!!! And if urgent I'm sure he will oblige :-)
Post by copper99 on Jun 4, 2013 21:25:59 GMT 1
Thanks guys, im hoping the pump will cure the woes, ive ordered it now, due Friday..
Post by Shytalk on Jun 6, 2013 10:31:15 GMT 1
Check around the bottom of the reed valve gaskets. Had a similar issue awhile back when bike was stood for a while. 2t had soaked through gaskets dripped onto crankcase & through the drain hole behind the barrels. OEB OEB what was the cure for yours?
Post by oldelsieboy on Jun 6, 2013 18:36:43 GMT 1
Check around the bottom of the reed valve gaskets. Had a similar issue awhile back when bike was stood for a while. 2t had soaked through gaskets dripped onto crankcase & through the drain hole behind the barrels. OEB OEB what was the cure for yours? Initially I fitted new reed valve gaskets which lasted a while but did start to seep again. Now the motor is having a full rebuild so I will also have a gander at the pump. OEB
Post by 2cl on Jun 7, 2013 21:07:55 GMT 1
Check around the bottom of the reed valve gaskets. Had a similar issue awhile back when bike was stood for a while. 2t had soaked through gaskets dripped onto crankcase & through the drain hole behind the barrels. OEB OEB what was the cure for yours? Mine done this from under the reed gasket, it seems to be that inside the pump there is a ball bearing that sits in a groove? and is worn and will not shut off properly so oil will pass, I fitted a new pump £141 in 2011/12 and have not had any more leaks.
Post by copper99 on Jun 18, 2013 19:46:40 GMT 1
Conclusion to this.....I did have a new pump fitted and now the leak has gone, the worn pump was the cause of the leak... Just as essential, I dont have any nasty large air bubbles in my oil lines.. here is some pics of my old pump, it was mentioned it may have been from an air cooled RD, what do you think? [a href=" |http://thumbsnap.com/Ioe3wfRd"] |http://thumbsnap.com/Ioe3wfRd[/a] [a href=" |http://thumbsnap.com/IeoJar86"] |http://thumbsnap.com/IeoJar86[/a] [a href=" |http://thumbsnap.com/gZiqb72K"] |http://thumbsnap.com/gZiqb72K[/a]
Post by arrow on Jun 19, 2013 6:47:00 GMT 1
Why would you think its off an air cooled RD?
Post by copper99 on Jun 19, 2013 7:39:46 GMT 1
Have dropped you a PM mate.
Thats what the man who took it off advised me...I wouldnt know one from t'other.
