Post by fatfredfaefife on May 27, 2013 15:58:34 GMT 1
Happy bank holiday Just when I thought I was nearing the end! Fairly sure I know what the problem is but just want a few expert opinions before I part with any more hard earned! Purchased a new wiring loom (31L-82590-70) when I went to connect up all fitted apart from the ones to the generator, my thoughts are that this is a generator from a different model and all I need now is a 31k generator and all should be ok. See attached pix Many thanks Sandy
Post by Yogi on May 27, 2013 19:16:58 GMT 1
Don't know if its that easy,I've got a 31L an its a rd250ypvs , may be interchangeable, but not sure???
Post by midlifecrisisrd on May 27, 2013 21:34:08 GMT 1
The 4 way plug with round pins and 3 white wires is correct for an Lc2
No 4 white wires and round plug on stator then it aint lc2 31k.
steve
Post by fatfredfaefife on May 27, 2013 22:41:25 GMT 1
thanks Steve my thinking is at some point it has had the wrong generator put on. Def a LC2 matching numbers starting 31k. Cheers Sandy
Post by Shytalk on May 28, 2013 9:28:07 GMT 1
Yep the bottom picture isn't of standard wiring from the stator.
