grimmy
Post by grimmy on May 22, 2013 16:16:42 GMT 1
Took engine side cover off to look for a oil leak. I found it coming from the gear lever oil seal. Looking in the Haynes manual it says there should be a nylon spacer. where does this go. If it goes on the shaft between the engine case and the side cover mine must be missing.
Post by arrow on May 22, 2013 16:36:00 GMT 1
Norbo has them.
grimmy
Post by grimmy on May 22, 2013 16:49:25 GMT 1
So it just sits on the shaft between the casings then.
Post by LC_BOTT on May 22, 2013 17:36:53 GMT 1
Yes, loose fit to prevent damage to the shaft.
gringo
Post by gringo on May 22, 2013 21:44:57 GMT 1
That's it just stops the chain hitting and damaging the shaft
Post by Norbo on May 23, 2013 6:30:02 GMT 1
They are only a fiva
