Post by peted on May 18, 2013 10:52:00 GMT 1
Sorry for the dull question, but new to a 250LC...
Other than when the 2T oil is low in the tank, when should the oil light between the clocks come on?
Cheers
Pete
Post by oldelsieboy on May 18, 2013 10:59:37 GMT 1
Sorry for the dull question, but new to a 250LC... Other than when the 2T oil is low in the tank, when should the oil light between the clocks come on? Cheers Pete Oil level & neutral light will illuminate when ignition is switched on & will stay on until a gear is selected. Both will relight when neutral is selected. HTH OEB
Post by Deleted on May 18, 2013 11:00:35 GMT 1
Oil light should come on when ignition is on and bike in neutral to show you have enough oil in tank
Post by bryan on May 18, 2013 11:50:46 GMT 1
Oil light should come on when ignition is on and bike in neutral to show you have enough oil in tank its a buld test, otherwise you would not know if it was working if it never came on till you were low on oil.
Post by steve h on May 18, 2013 12:26:23 GMT 1
Just keep your eye on the tank as well.
Post by peted on May 18, 2013 21:17:48 GMT 1
Thanks....gave me a little shock when it came on when I came back frm the first ride and left it running in neutral on the side stand.
Re the tank....of course I will!
Post by Norbo on May 22, 2013 6:50:47 GMT 1
welcome to the forum.
toot
Post by toot on May 22, 2013 10:11:09 GMT 1
Oil pump failure always scares me with 2 smokes. I still have the habit of hovering my hand over the clutch lever in case of a seize ;D
