Post by andygasgas on May 16, 2013 19:51:33 GMT 1
Hello all having just been screwed over on a set of carbs on eBay I've been offered a set of tar carbs has anybody used these on a 250lc ? Thought if anybody had then this is the place to ask thanks Andy
Post by Deleted on May 16, 2013 21:41:39 GMT 1
Norbo has a set on his furry bike. But that's a 350. He will be along in the morning
Post by andygasgas on May 16, 2013 21:52:05 GMT 1
Ok no problem the 250lc is proddy tuned with microns so thought why not try something different
Post by Norbo on May 17, 2013 6:42:07 GMT 1
They arte an excelent up grade mate you notice better power all round.
Post by andygasgas on May 17, 2013 7:34:03 GMT 1
Nice thanks norbo
Post by Deleted on May 17, 2013 10:45:20 GMT 1
said he would be along in the morning ;D
Post by andygasgas on May 17, 2013 12:52:16 GMT 1
Yep right again lol wasn't pillow talk was it lol thanks for help
Post by Deleted on May 17, 2013 17:20:03 GMT 1
noooooooooo just know his routine, bed with a cup of Horlicks at 9pm up at 7 and check the forum ;D ;D
Post by andygasgas on May 17, 2013 20:57:57 GMT 1
Ok I believe you millions might not lol
Post by Norbo on May 17, 2013 23:19:42 GMT 1
7 LOL chance would be a fine thing to get a lie in till 7 only on a sunday
Post by steeley on May 18, 2013 5:57:28 GMT 1
andygasgas ,i have a pair of tzr carbs on my 350lc std ish tune with ram air sock filter and nickon pipes and i find they work ok .i did though do an air jet mod on them info on the web easy to do .google tzr carburetor.
Post by andygasgas on May 18, 2013 6:48:05 GMT 1
Thanks mate I'm off to have a look at a set on Monday I guessing you used the stock inlet rubbers ? Andy
Post by steeley on May 18, 2013 20:29:47 GMT 1
yes they push into the std inlet rubbers.just rememberd had the carbs bored to 30mm and fitted oil injection fittings from an rd 400 to the carbs .
Post by andygasgas on May 21, 2013 16:03:40 GMT 1
Got my tzr carbs today pity the choke tops are missing or did they work from a cable ? Only ever worked on 1 that was years a go
Post by steeley on May 21, 2013 18:29:06 GMT 1
yes mate they work from a cable.are the chokes still in the carbs .if so you can get a spliter box and a lever and make up some cables ,put the lever on the l/h bar job done.
Post by andygasgas on May 21, 2013 18:33:58 GMT 1
Yes mate the chokes are fitted the carbs are mint also got a new throttle cable so just need to sort out cables what would you use an old throttle cable splitter ? I've had a quick look and doesn't seem to be any tzr cables etc about thanks Andy
Post by cb250g5 on May 21, 2013 20:09:40 GMT 1
Post by steeley on May 22, 2013 18:18:02 GMT 1
hi i ended up useing rgv choke cables on mine.
Post by andygasgas on May 22, 2013 19:05:20 GMT 1
Thanks for all the ideas do you know which rgv cables you used ie from which model thanks Andy
Post by cb250g5 on May 22, 2013 19:52:04 GMT 1
Nope - think I got them from someone on here - the chokes fit the PWKs
Post by steeley on May 23, 2013 5:10:47 GMT 1
hi andy ,i used choke cables off a vj 22 .if you have a look on the vehicle wiring products site they do a handle bar lever for l/h 9.97 ,sure you could find some thing cheaper on the web.when i rebuilt my lc years ago i fitted rgv switch gear so i already had the lever.
