grimmy
2t oil
May 16, 2013 18:42:32 GMT 1
Post by grimmy on May 16, 2013 18:42:32 GMT 1
What 2t is recommended for the lc
2t oil
May 16, 2013 19:30:33 GMT 1
Post by arrow on May 16, 2013 19:30:33 GMT 1
The bikes are not fussy as to who makes the oil. Best to avoid most JASO FB oils as they don't keep the motor as clean as FC, FD oils.
Specs should be on the back of the bottle.
grimmy
2t oil
May 16, 2013 19:52:56 GMT 1
Post by grimmy on May 16, 2013 19:52:56 GMT 1
Is it best to use fully synthetic oil
2t oil
May 16, 2013 20:20:46 GMT 1
Post by copper99 on May 16, 2013 20:20:46 GMT 1
I was told semi whilst im running it in, then fully synth...im sure I put any old shite in it back in the 80s with no bother ....!!
2t oil
May 16, 2013 21:18:40 GMT 1
Post by arrow on May 16, 2013 21:18:40 GMT 1
Is it best to use fully synthetic oil Not necessarily, but I do. Some oils that are top spec (FD) can be semi's. For the certification, oils that are FD spec are run in the test engine for 3 hours, the test for the FB and FC oils are run for 1 hour in the test engine.
2t oil
May 18, 2013 20:54:24 GMT 1
Post by davey on May 18, 2013 20:54:24 GMT 1
Motul 710 is what i use , its a god oil
Post by skydemon on May 18, 2013 22:55:25 GMT 1
Me too 710 is good enough for the 500s in the day it's good enough for Elsie
2t oil
May 19, 2013 1:10:42 GMT 1
Post by arrow on May 19, 2013 1:10:42 GMT 1
Motul 710 is one of the best dedicated 2T oils money can buy. I use Valvoline Syn Power 2T, which is just as good.
2t oil
May 19, 2013 11:02:57 GMT 1
Post by philip on May 19, 2013 11:02:57 GMT 1
Castrol TT ?
2t oil
May 19, 2013 16:08:56 GMT 1
Post by copper99 on May 19, 2013 16:08:56 GMT 1
Motul 710 is one of the best dedicated 2T oils money can buy. I use Valvoline Syn Power 2T, which is just as good. Wheres the best place to buy these oils from nowadays chaps?...and while im on the subject, how long approx , in "normal" riding, is the range of the oil in the tank?
2t oil
May 19, 2013 16:18:38 GMT 1
Post by Denzil on May 19, 2013 16:18:38 GMT 1
I run Putoline TT sport oil and coolant and gearbox oil as some one on here said it is one of the best you can buy. I'm using it all the time and as iv just rebuilt it for the second time I'm using some good oil in it.
2t oil
May 19, 2013 16:30:29 GMT 1
Post by arrow on May 19, 2013 16:30:29 GMT 1
Motul 710 is one of the best dedicated 2T oils money can buy. I use Valvoline Syn Power 2T, which is just as good. Wheres the best place to buy these oils from nowadays chaps?...and while im on the subject, how long approx , in "normal" riding, is the range of the oil in the tank? I get my 2-stroke oil from a motor factor. The oil pump sends the oil into the motor at an average value of around 30:1 if the bike does 35 miles to the gallon then from full to when the light comes on is in the region of 280 miles. 36 litres/30 = 1.2 litres of oil
2t oil
May 19, 2013 21:38:19 GMT 1
Post by copper99 on May 19, 2013 21:38:19 GMT 1
Wheres the best place to buy these oils from nowadays chaps?...and while im on the subject, how long approx , in "normal" riding, is the range of the oil in the tank? I get my 2-stroke oil from a motor factor. The oil pump sends the oil into the motor at an average value of around 30:1 if the bike does 35 miles to the gallon then from full to when the light comes on is in the region of 280 miles. 36 litres/30 = 1.2 litres of oil Thansk mate...Funny enough, ha dthe light flickering on as I pulled up tonight, especially under braking, level sensor doing its job I guess. Still seems a lot of oil in the tank but ill top her up.
2t oil
May 19, 2013 21:40:39 GMT 1
Post by arrow on May 19, 2013 21:40:39 GMT 1
Yep, about 1/2 a litre left when the light comes on.
2t oil
May 19, 2013 21:52:21 GMT 1
Post by copper99 on May 19, 2013 21:52:21 GMT 1
Yep, about 1/2 a litre left when the light comes on. Thanks. The things you forget some 27 years after having had one! Thanks God for the internet (and expert advice like your good selves) when it comes to these things eh..
