Post by pouchy750 on May 12, 2013 17:46:54 GMT 1
Apart from the power valves on the YPVS RZ 350, are the parts for both engines the same as the Banshee YFZ 350 ATV?
Post by cb250g5 on May 12, 2013 18:47:29 GMT 1
No
Post by soccersmyth on May 12, 2013 21:07:21 GMT 1
The only thing the same are crank and clutch and pistons. Everything else is either slightly different like Clutch case, has no hole for oil pump drive. Cranckcases, have no hole for tacho cable drive.
Or completely different like Barrels, head, flywheel, stator.
Post by soccersmyth on May 12, 2013 21:08:34 GMT 1
Gearbox completely different too as ratios taller
Post by andygasgas on May 17, 2013 12:55:38 GMT 1
Used to race against banshee many moons ago once they were on the pipe they flew they used to scream but were reliable
