Post by pouchy750 on May 12, 2013 2:24:40 GMT 1
The seal around the gear lever shaft is leaking. I believe the shaft is worn & needs replacing.
Can you replace the shaft without splitting the cases?
Do I need to remove the clutch basket & withdraw the shaft from that side?
Any thing else I need to know?
Thanks
Post by steeley on May 12, 2013 6:12:07 GMT 1
yes you need to remove the clutch basket and pull the shaft from that side.norbo sells the shafts and seal ,also he has a modified bush ie longer that goes into the shaft hole l/h side.
